Garage door w/ glazing
Is a glazed garage door only marked off under the glazed opening side of the OP chart? Or do you mark off the glazing under the glazed area and the non-glazed under non-glazed?
Glazed overhead garage doors are only referenced in the table under Glazed Openings - Garage Doors. If verified as wind load rated, they are still “X”, and mark “N/A” on the non-glazed side for garage doors.
But if the entire assembly is impact, then it’s A on the glazed side and N/A on the non-glazed side right? Or would the non-glazed section also be marked as A?
Correct
No, if it’s a glazed door.
Thanks!
Has anyone seen a glazed impact rated garage door?
I do not remember ever seeing one.
Yes.
I’ve seen a few.
I saw one Mike. I believe that’s the only one I’ve seen though.
Bert
I have seen it 2 times…and I was surprised… Both on High End homes
