Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Florida Inspectors
Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections.
Old 8/10/10, 5:19 PM
Michael J. Meeker's Avatar
Michael J. Meeker Michael J. Meeker is online now
Default Measuring roof perimeters
Well I had to measure a roof perimeter today for a wind mit and I have a question for you pros.
Do any of you use a laser device? If so do you just point to point a then to point b and move on?
If not how are they used?
How many stories high can you measure from the ground. My plan is to measure the fascia.
Can you see a dot on your target for accuracy?
I used a rolling wheel today and I can see it's future limitations especially on two story structures.
Is anyone using a different method that works well for you?
Are there any problems with using the laser in the manner I am describing or outside in bright sunlight?
If you use one and you would recommend it please let me know what the model is and the approximate cost.
Any input for measuring the perimeter of a structure would be appreciated. Thanks in advance.
Florida Licensed General Contractor
Florida Licensed Home Inspector #299
Wind Mitigation Specialist
Call 954-922-0584 or E-Mail Me For The Best Wind Mitigation Inspection in Florida at a Great Price
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/10/10, 5:46 PM
John Shishilla's Avatar
John Shishilla John Shishilla is offline
Default Re: Measuring roof perimeters
Lasers are limited, you need a item to point it at. On a plain square house it could be difficult if not impossible. Some of the better models will figure the hypotenuse and in theory this would work to measure the fascia. I use two different wheel types, small and large. I use the small one to measure flat roofs(from the top) and the large wheel through the yard. You could also measure a wall by holding it side ways instead of on the ground. One of my inspectors is an appraiser, he uses a tape measure and a laser.
All that being said, I am thinking of buying a laser measure device also. Probably a cheap unit from Home Depot about $100.
let us know if you get one and try it out.
John Shishilla
State of Florida Licensed Home Inspector #21
Residential Contractor
Accredited Claims Adjuster (ACA)
Mold Assessor MRSA 1544
President of Fl Home & Insurance Inspectors Chptr
VP of Nachi Managment
Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas.
Honor Construction Inspection Service
www.honorconstruction.com
"Because details matter"
321-327-2950
Old 8/10/10, 5:52 PM
Thanks John I will let you know if I get one and how it works.
If anyone has any ideas please let us know.
Old 8/10/10, 6:49 PM
Andrew Ricke Andrew Ricke is offline
-For Broward county the tax appraisal's office www.bcpa.com has the exterior wall layout with dimensions for most homes.
-I have taken an index card and taped it at an outside corner and let it hang out beyond the wall to have a place for the laser to target.
-The laser device I have when placed flat on the wall doesn't let the laser go down the wall enough so I place a small spacer (small piece of wood shim) on the back of the device to bring it off the wall just enough to shoot further down the wall.
-if all the soffits extend out the same on the house just measure the perimeter walls. Your only getting a measurement to see if the 10% rule applies right?
Andrew Ricke
Serving South Florida
4DBuilding Information Group Inc
http://www.4dbig.com
Old 8/10/10, 6:58 PM
Yep the 10%.
I see how you are saying it works. I was hoping to point to point A then point to point B and get that distance. I will not get one if I have to do it like you are saying. thanks for letting me know how that one works. what model is it so I do not get it.
If anyone knows of a model that will let me point to point A then point to point B and get that distance.Please let me know.
Old 8/10/10, 8:42 PM
John W. Miller John W. Miller is offline
Michael,
I use a wheel measure but I saw a demo by a Bosch tool rep and they have a sweet little handheld device that does the calculation you need. I think it was $300.00 approx. Kinda expensive but I have had good luck with Bosch tools.
John
PRP Home Inspections
Old 8/10/10, 9:16 PM
Thanks John i'll try to find it. Any idea what it is called?
Old 8/10/10, 9:49 PM
Hey Michael,
I forget what the model was but I saw it at a Lowes in a demo. The Bosch rep said not all Lowes would carry it. It was as small as a cell phone and did some amazing stuff.
John
Old 8/11/10, 6:41 AM
William P. Campbell William P. Campbell is offline
Mike,
I have used in a quick analysis to get the building square footage off the county website to save time in determining the perimeter linear footage. To give you an example on a 3000 sq ft home. That would be 60' x 50'. That would equate to 60 +60+50+50=220'. I use it when it's not close. It doesn't include overhang which creates a buffer.
Prestige Property Enterprises,Inc
Bill Campbell
Certified Building Contractor
CBC1257312
HI-904
Old 8/11/10, 3:18 PM
Aubrey J. Kahn Aubrey J. Kahn is offline
Michael, all laser's need a target that they can hit, otherwise it is unable to measure distance.
Old 8/11/10, 4:59 PM
I understand that. I think I heard somewhere you can point to object A then to object B and it will tell you the distance between the 2 but I may be mistaken.
I would like to walk the perimeter of the house and and measure the roof line from the ground.
Old 8/11/10, 5:00 PM
George E. Russell George E. Russell is offline
The old fashioned way still works....a ladder and tape measure should already be a part of your tool kit
George Russell
George Russell Professional Inspections
Austin,Texas
TREC # 10215
512-296-9538
http://georgerussellprofessionalinspections.com/
http://www.facebook.com/austinhomeinspections
Old 8/11/10, 5:04 PM
I would like to be able to do it in under a day.
Old 8/11/10, 9:08 PM
Randy L. Mayo, PE's Avatar
Randy L. Mayo, PE Randy L. Mayo, PE is offline
Michael
To calculate the roof perimeter just measure the house at ground level at the drip line and add a correction factor for gable ends. I have attached an example with a gable end factors for common pitches.
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 8/11/10, 9:12 PM
Randy,
Thanks, i'll check it out.
Everyone: I am still looking for the device if it exists.
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 12:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
