Technically the door has been altered which would nullify the approval. However, being so small, it may not show up in the photos. Kind of like that gray area with cat doors.
Mike,
Even w/o the design pressure label, that door does not have enough horizontal bracing to qualify as meeting today’s residential codes. It’s most likely the original unit installed during construction, so based on the door photo alone, I’d bet it’s as old as the home.
PS: The ole builder’s “rule of thumb” is you never perform on-site alterations to any engineered product w/o an Engineer’s letter of approval for said alterations.
It is not currently an issue due to nothing else is protected but I do not believe a re-inspector would accept anything less than an approved product. Any citizens re-inspectors out there?
I cannot either but typically when things are modified or altered they lose whatever credibility they gained from testing as the door or one like it was never tested when modified in that way.
Someone mentioned catdoors, I mark them and dog doors as unprotected. Wind certainly will penetrate.
Designer Windows
A variety of beautiful choices is available. Use
acrylite instead of glass for safety and
durability. Martin Doors’ Vista« window line is
a separate offering featuring bevels, textures
and caming choices.
Accessories
• Vents - Available in white or brown
• Mail slots - Available in brass or brushed aluminum
