Is this product considered an SWR for the purposes of the wind mitigation form? If not, why?
Probably only if it has been Dade County approved
Doesn’t say much about water retention, does it. It may count as roof deck - B though.
Closed Cell Foam is an SWR. It would need to have testing in Florida to be an SWR and to increase uplift resistance.
It would appear this has been tested with the article mentioning the Florida building code right? If they can provide the FL#
From what I heard at the last meeting, NO, it has to be peel and stick on TOP of the seams of the deck, and has to have documentation for such
Apparently if it is a sprayed ADHESION system and not a sprayed foam system, it does count as SWR. Which this is…
