Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Florida Inspectors
Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections.
Old 12/15/11, 11:04 AM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Default Screen cage question
Please note in the picture it appears that screen splining is missing/not installed in numerous areas and I personally think it compromises the integrity of the cage and the install.
Does anyone know where I can find Florida information on this. Sellers are questioning my report and would like to give them a place I can professionally refer them to. Thanks in advance
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/15/11, 11:58 AM
Eric C. Van De Ven's Avatar
Eric C. Van De Ven Eric C. Van De Ven is offline
Default Re: Screen cage question
If the area you are referring to are the "X" braces, it doesn't need to be there.
If you are talking about the center brace, it may not be needed there either as the channels that run front to back appear to be adequate.
Old 12/15/11, 12:28 PM
John Shishilla's Avatar
John Shishilla John Shishilla is offline
I would call it a poor install, but not related to the structure, formally installing them for a living. The structure should be fine.
John Shishilla
State of Florida Licensed Home Inspector #21
Residential Contractor
Accredited Claims Adjuster (ACA)
Mold Assessor MRSA 1544
President of Fl Home & Insurance Inspectors Chptr
VP of Nachi Managment
Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas.
Honor Construction Inspection Service
www.honorconstruction.com
"Because details matter"
321-327-2950
Old 12/15/11, 12:40 PM
David A. Andersen's Avatar
Extra stuff for potential "Snow Load" !
You know, global warming...
BPI# 5015804
Old 12/15/11, 1:00 PM
Michael J. Meeker's Avatar
Michael J. Meeker Michael J. Meeker is online now
As I have NO experience other than having had screen enclosures in the past I am asking to learn.
Wouldn't it be structurally stronger if all were splined? Not necessarily necessary but better?
In other words how would you do it if it were yours?
Florida Licensed General Contractor
Florida Licensed Home Inspector #299
Wind Mitigation Specialist
Call 954-922-0584 or E-Mail Me For The Best Wind Mitigation Inspection in Florida at a Great Price
Old 12/15/11, 1:09 PM
I spline most of mine only to hold the screen better. It is very common to not spline many sections. With the engineer you mileage may vary. I would say if you are relying on screen and spline for support you may want to add additional framing members.
John Shishilla
321-327-2950
Old 12/15/11, 1:14 PM
Thanks. I will keep that in mind if I ever get another screen enclosure.
Old 12/15/11, 1:16 PM
My concern would be that when high winds come would a large screen only held down in a couple places be more susceptble to lifing off. Wouldn't a large one peice screen be more wind restrictive than a small screen?
Donate here:
Melbourne, Fl 32901
Old 12/15/11, 1:20 PM
I would be more concerned with it blowing out because of the missing spline.
John Shishilla
321-327-2950
Old 12/15/11, 2:29 PM
William C. Chandler William C. Chandler is offline
I'm not a screen expert but it looks like most I look at
www.thebuildinginspector.net
William Chandler
Licensed Home Inspector #1025
Certified General Contractor #CGC060389
FHA 203(k) Inspector #A0954
Licensed Radon Measurement Technician #R2275
Certified Pollutant Storage Systems Contractor #PCC052624
Certified Underground Utility & Excavation Contractor #CUC057349
Old 12/15/11, 3:47 PM
The screen itself, in most newer enclosures anyway, has nothing to do with the structure. Looking at the picture, it appears as though they used splines on the front to back runs and then, on the ends. If the screen was placed properly, as you insert the spline, it "tightens" the screen. If you were to try and add some splines, it either wouldn't fit in the grooves or would tear the screen.
The enclosures themselves are strong enough, that, and perhaps John can add to this as he has probably done it this way, you can walk on the beams to install the splines. I saw a couple of guys that rescreened an entire enclosure in an hour! They just rolled out the screen, one guy did one side, the other guy did the other side and they just went right across the screen.
They must have worked in the circus!
On the other hand, when I replaced all of my screens after Wilma, I used some 2 x 12 x 10s so I didn't end up in my pool...or concrete deck!
Old 12/15/11, 4:02 PM
Hey Russell,
give kevin a call http://www.screendoctorsllc.com/contactus.htm
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 12/15/11, 4:50 PM
Bruce..thanks.I appreciate that very much and everyones help and I will post what he tells me.
Would be a great article...how to inspect creen enclosures or Lanai's as they are called down here.
Donate here:
Melbourne, Fl 32901
Old 12/16/11, 6:11 AM
Todd A. Miller Todd A. Miller is offline
I agree with Eric.... The screen has nothing to do with the structural integrity of the cage. The corner bracing, gussets, angle braces at the frame studs, the tie down bolts all are important. Screen splined in or not splined in is all about the bugs and speaks to the quality of the installers and attention to detail.
HomeSpec Certified Inspections, Inc.
Providing inspections throughout Southwest Florida.
www.sarasotahomeinspector.biz
www.swfhomeinspector.com
www.ftmyershomeinspector.biz
Contact me at: hscertified@gmail.com
Call or text: (941) 270-1349
InterNACHI # 10110112
Fla License # HI959
Facebook
LinkedIN
Old 12/16/11, 11:11 PM
Humberto Carvajal's Avatar
Humberto Carvajal Humberto Carvajal is offline
Russell try this link to the Aluminum Association of Florida Inc. You may be able to download their manual from here...
http://www.aaof.org/main/page_downloads.html
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEEDŽ Accredited Professional
Member USGBC South Florida Chapter
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Powwer Point Question bsmith Miscellaneous Discussion for Inspectors 2 1/23/07 10:50 AM
Help. My START menu is on the right of my screen. gromicko Miscellaneous Discussion for Inspectors 24 12/21/06 4:47 PM
draw inspection form question... krea General Inspection Discussion 6 10/19/06 5:16 PM
