FUBAR:shock: Was this done to control ponding? The deck nailing is now not functioning as designed (non-conforming wind load diaphragm), and the nails will eventually work its way thru the roofing membrane (I assume it is a flat roof). This should have been done with continuous sistering secured to the decking using polyurethane adhesive, but still would have needed engineering approval.
