Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Florida Inspectors
Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections.
Old 11/29/12, 10:39 PM
James A. Nadeau James A. Nadeau is offline
Default Vent from garage to laundry room
I found two vents going from the attached garage to the laundry room(air conditioned space). It appeared that someone cut 10 or 12 inch square holes and screwed a few vent covers on them. The holes were next to the walk thru door and one was near the ceiling and the other near the floor lined up in the same vertical plane. I recall something about not having a vent from the garage to living space.
Of course the Realtor thought it was required because the water heater is gas operated and needed a vent. He did mention that the laundry hook ups were available for a gas dryer.
Is this a problem?
Thanks
Ps I wasnt there for a inspection at the time.
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/30/12, 1:49 AM
Bob Elliott's Avatar
Default Re: Vent from garage to laundry room
Garage has exhaust fumes and air is being pulled in to the living space?
Yes that is a very big problem.
Air conditioned means returns.
Old 11/30/12, 6:49 AM
Fred Sylvester's Avatar
Fred Sylvester Fred Sylvester is offline
Without further information or photos, I would agree with Bob. This would be even a bigger problem if the building is opertaing in negitive pressure.
PO BOX 61664
Fort Myers, FL. 33906
239-936-7579
HI-278~~~~~CB-C025051
Building Inspections since 1993
Old 11/30/12, 7:11 AM
What do you mean by negative pressure?
Thanks for the replies.
Old 11/30/12, 7:59 AM
Clint VanNest's Avatar
Clint VanNest Clint VanNest is offline
There would also be an issue with the break in the firewall.
Clint VanNest
St. Cert. Res. Appraiser RD6117
Home Inspector HI5007
Serving Orange & Osceola Counties.
Old 11/30/12, 8:07 AM
http://www.buildingscience.com/docum...ding-envelopes
PO BOX 61664
239-936-7579
Old 11/30/12, 8:10 AM
Scott P. Surridge Scott P. Surridge is offline
There needs to be make up air for the gas water heater at the interior heated space. This is done with a grill in the ceiling and a lower air chase with the grill about 12" off the floor. What is there is a breech of the firewall and is not considered make up air.
Old 11/30/12, 8:24 AM
Barry Adair's Avatar
take a straw
suck = negative pressure
blow = positive pressure
unassisted, direct draft combustion appliances suck their combustion and draft air, thus negative pressure has to be pulled into the unit for proper function
ask yourself where does this air come from and what replenishes it for proper continued operation?
it can not convey directly from the garage air to the living space
living space and garage fire separation change in the irc
http://media.iccsafe.org/news/eNews/...0/IRC302.6.pdf
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
life is the random lottery of events followed by numerous narrow escapes, accept the good
Old 11/30/12, 8:30 AM
Here is another web page that is not so technical as Joe's
http://www.ecoevaluator.com/building...-boundary.html
PO BOX 61664
239-936-7579
Old 12/1/12, 9:17 AM
Great info
The Gas fired water heater is actually in the garage. Now I didnt look for any dedicated vents inside the garage, should there be?
Old 12/2/12, 9:35 PM
William H. Smith William H. Smith is offline
Great info
There needs to be a make up air from the outside for the gas equipment in the garage. Vents into the residence is WRONG and need to go. If there is gas equipment in laundry room with a door it also needs to have combustion and make up air vents (withing 12" of floor/ceiling) to an exterior room with acess to the exterior or vented to the exterior directly
Dryer Vent Cleaning, Westtown PA 19395 nhagarty Ancillary Inspection Services & Additional Topics 1 9/24/11 5:06 PM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Room over garage mivie Structural Inspections 20 1/17/10 10:08 AM
Duct from above furnace in laundry room..... shand Inspecting HVAC Systems 6 7/1/09 10:58 AM
Common wall of garage is Laundry room / firewall ? dnasser Interior Inspections 14 6/26/09 11:57 PM
