| Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections. |
I inspected a home today (1975) that had rebar in the corners but not at the openings. I am writing it up as Unreinforced Masonry. This is the first one I have come across like this so far. So............
Does everyone agree with this? Thanks! Lee Curtis - Home Inspector Revealing the Secrets of Your Home! CGC1519195 - HI3222 - InterNACHI #11011001 Lee@CurtisHomeInspections.com www.CurtisHomeInspections.com www.CurtisHomeDesign.com |
| Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
How were you able to determine there was no rebars inside the block at the corners.? Any pics? Curious
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I myself would rate it as reinforced if in addition to the corners, there was a continuous tie beam with rebar.
However, I believe that outside the HVHZ. Rebar is required at at least one side of the doors and at the window header. It would be nice if someone would post one of those nice charts York uses. Your Home Inspection & Wind Mitigation Provider Jay C. Murray Florida Home & Insurance Inspector Chapter Board Member Licensed General Contractor & Home Inspector Serving Port St. Lucie, Ft. Pierce, Stuart, Palm City, Jensen Beach, The Palm Beaches, & The Treasure Coast |
Reinforced grouted cells are required at windows, doors, and depending on the year of construction here between 4 and 8 feet of wall. There are also requirements for the lintels and at the top block. Suffice it to say that if no reinforcement (deformed steel rods can be detected) at every building opening a reinspector will mark the structure as unreinforced. Code notwithstanding the enginneer of record is never challenged on the design. They ought to be.
Give the guy a break it's a ZIRCON and it works pretty good for a hundred bucks, we also use it to determine the nail spacing for the roof sheathing. That's some of us at least.
Brian, reinforcement every 8 ft. in the walls may be part of the current building code. But I don't believe that outside of the HVHZ, it is required for the reinforced masonry credit.
At the Melbourne meeting, York spoke about this and showed a chart detailing the different requirements for this rating. I love to see a copy of that chart. Your Home Inspection & Wind Mitigation Provider Jay C. Murray Florida Home & Insurance Inspector Chapter Board Member Licensed General Contractor & Home Inspector Serving Port St. Lucie, Ft. Pierce, Stuart, Palm City, Jensen Beach, The Palm Beaches, & The Treasure Coast |
http://www.maconline.org/tech/materials/cm/cm.html
http://www.oas.org/cdmp/document/codedraw/intro.htm LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
NACHI Online Education:
How to Perform Wind Mitigation Inspections, Section 9 - Reinforcement Check, States: IMPORTANT: You must located vertical re-bar at a minimum of two corners and next to one window or door opening to classify the wall as “Reinforced Masonry.” That's what I am going with although personally I am not convinced it is correct. Lee Curtis - Home Inspector Revealing the Secrets of Your Home! CGC1519195 - HI3222 - InterNACHI #11011001 Lee@CurtisHomeInspections.com www.CurtisHomeInspections.com www.CurtisHomeDesign.com |
John Shishilla State of Florida Licensed Home Inspector #21 Residential Contractor Accredited Claims Adjuster (ACA) Mold Assessor MRSA 1544 President of Fl Home & Insurance Inspectors Chptr VP of Nachi Managment Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas. Honor Construction Inspection Service www.honorconstruction.com "Because details matter" 321-327-2950 |
Just make sure you take the safety plastic off the little window before you use it. I did two inspections before I figured out why the black lines wouldn't go away.?. I works much better now! Lee Curtis - Home Inspector Revealing the Secrets of Your Home! CGC1519195 - HI3222 - InterNACHI #11011001 Lee@CurtisHomeInspections.com www.CurtisHomeInspections.com www.CurtisHomeDesign.com |
Seen those quite a few years ago, the price has gone down considerably.
| Vertical cracking in reinforced masonry | mtyson | Structural Inspections | 7 | 2/24/11 1:21 PM |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 2:59 PM |
| What might cause this many cracks? | bhamilton | Structural Inspections | 15 | 2/25/09 12:44 PM |
| House panel votes to add wind coverage | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 7/28/07 10:45 AM |
