| Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections. |
dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Which of the following should be considered an opening that requires protection?
A). Gable end vents? B). Window a/c units mounted in windows and walls? C). Glass block - real glass block set in mortar? D). Acryllic block window units? E) Windows in overhead garage doors? |
| Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
A=no
B=yes C=no D=yes E=yes Prestige Property Enterprises,Inc Bill Campbell Certified Building Contractor CBC1257312 HI-904
Gable end vents do require protection. Glass blocks need protection in Miami Dade and Broward
www.wisemovehomeinspection.com Carl Pennick Lighthouse Point, FL 954-946 2737 407-928 8489 Florida Licensed Home Inspector #65 NACHI #04072098 ICC #5294144 Certified Master Inspector |
B). ??? Looking for input C). Glass block set in mortar has not been tested to any extent to my knowledge, and would therefore need protectection. Although some contractors lay dur-a wall or horizontal wire reinforcing between block courses, I believe these still need to have protection. D). Yes E). Yes Last edited by dquigley; 8/18/10 at 7:46 PM.. |
As far as i am concerned all due to how the form is written. I try to go by what the form states and I leave the interpertation up to underwriters and such. If I say something because someone else says so then I am still responsible. As far as I am concerned the form needs to be much more exact maybe they will get it right in September.
Florida Licensed General Contractor Florida Licensed Home Inspector #299 Wind Mitigation Specialist Call 954-922-0584 or E-Mail Me For The Best Wind Mitigation Inspection in Florida at a Great Price
Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
I would be interested to know what they reqiure, probably some horizontal reinforcement like durawall |
b.in windows-yes, walls- no c.yes - pittsburgh corning has small missile approval d.yes e. yes * Some items are subjective and are not listed on the form, you could technically classify these in the ect. category. Items such as gable vents, crawl space vents, mini split a/c units, roof turbine vents, ect.. have only been adressed in an opinionated fashion and have not been officially identified as "openings" for wind mitigation purposes. Until there is an official list of the "grey area" items, I will only "inspect" openings which are identified on the 1802 and/or listed and described in "approved" wind mitigation educational material. |
Dennis,
Do you know what Universals size threshold is? |
No, and the funny thing is, niether do they. I have spoken with some of the underwriters at length. Gable vents came up, and I was told that protection depended on size, but the size was unknown... It was and has always been a "whose on first" routine with the grey areas on the form. I have chosen not to read into the form(as york suggested).. Who am I to determine what falls under the ect. category? Do crawlspace vents or soffit vents count?
My training stated glass block should be treated like masonry block. However logic should certainly be dependent on the quality and reinforcement in the glass block installation.
| wind scenario #4- RDA | dbonner | Florida Inspectors | 17 | 8/16/10 12:45 AM |
| Wind Mit Scenario #3 (Roof Calc) | dquigley | Florida Inspectors | 20 | 8/14/10 8:21 AM |
| Wind Mit Scenario #2 | dquigley | Florida Inspectors | 14 | 8/13/10 5:37 PM |
| Wind Mit Scenario 1 | dquigley | Florida Inspectors | 13 | 8/12/10 12:20 PM |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 2:59 PM |
