| Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections. |
| View Poll Results: Roof to Wall Attachment: What is the weakest roof to wall connection? | |||
| Toe Nail |
11 | 39.29% |
| Clips |
4 | 14.29% |
| Single Wraps |
1 | 3.57% |
| Double Wraps |
0 | 0% |
| Structural |
1 | 3.57% |
| Other |
2 | 7.14% |
| Unknown or Unidentified |
6 | 21.43% |
| No attic access |
3 | 10.71% |
| Voters: 28. You may not vote on this poll | |||
Here is a classic, which is it?
Roof to Wall Attachment: What is the weakest roof to wall connection? A. Toe Nails Rafter/truss anchored to top plate of wall using nails driven at an angle through the rafter/truss and attached to the top plate of the wall. B. Clips Metal attachments on every rafter/truss that are nailed to one side (or both sides in the case of a diamond type clip) of the rafter/truss and attached to the top plate of the wall frame or embedded in the bond beam. C. Single Wraps Metal Straps must be secured to every rafter/truss with a minimum of 3 nails, wrapping over and securing to the opposite side of the rafter/truss with a minimum of 1 nail. The Strap must be attached to the top plate of the wall frame or embedded in the bond beam in at least one place. D. Double Wraps Both Metal Straps must be secured to every rafter/truss with a minimum of 3 nails, wrapping over and securing to the opposite side of the rafter/truss with a minimum of 1 nail. Each Strap must be attached to the top plate of the wall frame or embedded in the bond beam in at least one place. E. Structural Anchor bolts structurally connected or reinforced concrete roof. F. Other: ______________________________________ G. Unknown or Unidentified H. No attic access John Shishilla State of Florida Licensed Home Inspector #21 Residential Contractor Accredited Claims Adjuster (ACA) Mold Assessor MRSA 1544 President of Fl Home & Insurance Inspectors Chptr VP of Nachi Managment Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas. Honor Construction Inspection Service www.honorconstruction.com "Because details matter" 321-327-2950 |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
dquigley is a non-member guest and is in no way affiliated with InterNACHI or its members.
oops
I'm changing my answer --- didn't notice the pics The answer is "F" other --- Straps are to far away from truss Last edited by dquigley; 8/20/10 at 6:43 PM.. |
Not from Florida, but that is irrelevant...
Answer would be H... You cannot rate a connection that you cannot see, or verify even exists. Answer would not be G (unknown), because G also contains (unidentified). Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
but the pictures are right there, I can see the connection. John Shishilla State of Florida Licensed Home Inspector #21 Residential Contractor Accredited Claims Adjuster (ACA) Mold Assessor MRSA 1544 President of Fl Home & Insurance Inspectors Chptr VP of Nachi Managment Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas. Honor Construction Inspection Service www.honorconstruction.com "Because details matter" 321-327-2950 |
Oops, you're right John, sorry.
I read through the Poll choices, then through the opening post for more details, and skipped over the pics to see what others have posted. My post was a general statement (as your poll indicated by it's choices). I didn't realize the poll was to determine the connections in the pics. My apologies. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Same here, I went back and revised my original post -- nice feature
I agree. There is also not enough nails.
Greg Bell Titusville, Fl 02111507 Serving Central Florida
by definition(as the form reads) those are clips..
Why are they clips?
to me they are improperly installed straps |
they are poor straps, but dont have 3 nails on face and one on back- so they dont qualify as Single Wrap straps. but they are metal attachments on every truss that are nailed to one side and embedded in the bond beam, no?
If that is the case; then wind mit Scenario #7 would qualify as clips also. That is what I posted in that Scenario, not enough nails for wraps. That was my point of posting this. I would easily mark this as clips, but WM SCenario #7 would be more difficult even though they both meet the definition on the form. John Shishilla State of Florida Licensed Home Inspector #21 Residential Contractor Accredited Claims Adjuster (ACA) Mold Assessor MRSA 1544 President of Fl Home & Insurance Inspectors Chptr VP of Nachi Managment Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas. Honor Construction Inspection Service www.honorconstruction.com "Because details matter" 321-327-2950 |
I would like to hear how you would get toe nails or no access from this scenario.
I agree that according to the form they are clips. We're using our own subjectivity in saying they're not because they aren't 1/4" away or less. As far as wraps. My interpretation as far as nails is that there must be at least 3 nails total with one of those three nails on the opposite side and that 4 total nails are not needed to meet the criteria of a single wrap. What's your take.
Prestige Property Enterprises,Inc Bill Campbell Certified Building Contractor CBC1257312 HI-904
To qualify as single wraps- they need to have 3 nails on one side, wrap over and have at least 1 nail on the other side. Thats 4 nails total to qualify for single wraps. This i am 100% confident of being the current industry standard.
| Wind Mit Scenerio #7 | jmurray4 | Florida Inspectors | 20 | 8/22/10 6:56 PM |
| Wind Mitigation Certification for Florida | rbassett | General Inspection Discussion | 7 | 8/17/10 6:19 PM |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 2:59 PM |
| House panel votes to add wind coverage | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 7/28/07 10:45 AM |
