Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Florida Inspectors
Florida Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida inspection topics, wind mitigation inspections and 4-point inspections.
Old 2/2/12, 3:27 PM
Michael J. Meeker's Avatar
Michael J. Meeker Michael J. Meeker is offline
Default Wrap or nothing?
What do you all think based only on what you can see.
This was from an old inspection.
The definition of a wrap is now.
C. Single Wraps
Metal connectors consisting of a single strap that wraps over the top of the truss/rafter and is secured with a minimum of 2 nails on the front side and a minimum of 1 nail on the opposing side.
What if the nails are reversed as they are in this photo. 1 on the front 2 on the back. Does anyone know for sure if it is a wrap or not? I think we can all agree it should be accepted but is it.
For arguments sake even if you do not agree that the photo represents that situation what do you do if you see the situation I am describing?
Florida Licensed General Contractor
Florida Licensed Home Inspector #299
Wind Mitigation Specialist
Call 954-922-0584 or E-Mail Me For The Best Wind Mitigation Inspection in Florida at a Great Price
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/2/12, 3:47 PM
Eric C. Van De Ven's Avatar
Eric C. Van De Ven Eric C. Van De Ven is offline
Default Re: Wrap or nothing?
C. Single Wraps
A picture would be nice!
Minimal conditions to qualify for categories B, C, or D. All visible metal connectors are:
ı Secured to truss/rafter with a minimum of three (3) nails, and
ı Attached to the wall top plate of the wall framing, or embedded in the bond beam, with less than a ½" gap from the
blocking or truss/rafter and blocked no more than 1.5” of the truss/rafter, and free of visible severe corrosion.
ı B. Clips
ı Metal connectors that do not wrap over the top of the truss/rafter, or
ı Metal connectors with a minimum of 1 strap that wraps over the top of the truss/rafter and does not meet the nail
position requirements of C or D, but is secured with a minimum of 3 nails.
ı C. Single Wraps
I would guess if it has three nails, two on one side and one on the other, then the side with two nails would be the front.
Maybe the builder was left handed.
Old 2/2/12, 3:53 PM
woops stand by
Old 2/2/12, 3:54 PM
It is now there. I assume where it exits the cement is the front?
I would not think it matters but I apparently do not know much because I think a wrap with 2 nails is better than toenail.
Old 2/2/12, 4:07 PM
That is a good question.
What is the "front"?
Is it the front of the house, or as you stated, where the strap goes into the concrete?
It won't matter much as they won't get credit for re-nailing the deck as most of the nails missed the truss.
Old 2/2/12, 4:12 PM
Another thing brought up in last nights class was. How do you know that the roofer did not see he missed and go right back and nail it properly.
If he did not HAVE to remove the missed nails he would likely just put them in where they go. It did after all pass the inspection and that is how we determine if something meets the code.
Old 2/2/12, 4:14 PM
I am not worried about getting sued but I imagine somewhere there is going to be a client that paid a lot for the new roof and will not get a discount because of this.
Look out roofers.
Old 2/2/12, 4:16 PM
Logic.
Whoever installed the nails didn't know they missed the trusses because they used an air gun to install them.. If they didn't know that they missed the trusses, what on earth would make anyone believe that they went back and renailed them?
Here are a bunch more New Roof=Fail
And, as is evidenced on this report Tamarac roof, the code requirement is to remove all nails that did not make contact with the truss.
I am still trying to find out about the nails and front issue.
Old 2/2/12, 4:19 PM
Clint VanNest's Avatar
Clint VanNest Clint VanNest is offline
I would think lift wise, 2 nails on the side that wrapped over would be higher than 2 nails on the side coming from the wall. But I'm no engineer.
I'm still waiting to make an order with John on those magnetic nail heads he mentioned.
Clint VanNest
St. Cert. Res. Appraiser RD6117
Home Inspector HI5007
Serving Orange & Osceola Counties.
Old 2/2/12, 4:21 PM
Are inspectors not required to actually check when a roof is re-nailed before marking sheathing as passed?
If not what a joke.
Old 2/2/12, 4:25 PM
If not what a joke.
No, they are not. An affidavit from the roofer suffices in most instances. The only times an inspector will come out is if he is called to inspect a specific issue. It is what had to be done on the failed roofs on my roof page. Once the city inspector came out and red tagged the job, things got done.
It is now the first thing I tell my clients to do before they close on the home when I run into this. I have been writing it up on my reports for years.
Just another way I piss everyone off.
Now, with the wording in the course with regards to this matter, a lot of sales are going to fall through because of it.
Old 2/2/12, 4:49 PM
The problem is ONLY home inspectors need the training so only Home Inspectors will know this and only home inspectors who take the newest course.
Once most folks are qualified to do something that is where they stop.
Very few actually try to stay on top of things like those we see daily here discussing the issues.
As far as I am concerned if it does not ask it on the form the information is not required.
I do not believe the insurance companies have the right to add whatever they wish to the way things are done. If it does not state something on the form I do not believe it should be taken into consideration.
That does not mean I believe it is the correct way or not to do something but I do believe if it is a must then it MUST say so on the form.
You want my opinion on the matter I believe everyone doing them should have to take new training whenever there is a new form. I personally would hate it but at least most would be on the same page.
I also have problems with that because the classes are nothing but opinions. Nothing that is not on the form should be taught as fact.
The guy from last night teaches things as fact when he admits that he adds things based on what inspectors tell him insurance companies require and he speaks as if the OIR and Citizens are one.
I believe that crap is wrong. I believe opinions should not matter and only the facts to the questions on the form whatever the form may be should matter.
Old 2/2/12, 4:55 PM
I agree with you on that. Unfortunately, Citizens, the OIR and all the other "big fish" control things. The form is there. Plans are in the works to have everyone who has anything to do with the form is required to pass a course. John is working on a handbook. I think everything should have been done first before the form was released, but at least things are being done.
As for your instructor from the course, after he made this statement: How do you know that the roofer did not see he missed and go right back and nail it properly., I would have walked out.
Old 2/2/12, 4:59 PM
He did not say that. He taught it as you say. A inspector said that.
He himself is a York student. I about walked out anyhow but I did not wish to be rude. He was a nice guy and his course is approved but I just feel the whole system is flawed.
Old 2/2/12, 5:10 PM
Sorry then.
It is a statement I have heard Realtors ask. I really have to bite my tongue when responding to them.
I asked John S. about this issue a couple weeks back and he gave a very good detailed answer as it pertains to codes and insurance coverage.
Protecto Wrap vsantos Exterior Inspections 9 2/17/09 8:38 AM
House Wrap brepanshek Exterior Inspections 26 10/4/08 9:45 PM
Composite siding with paper thin vinyl wrap wohara Exterior Inspections 1 5/19/08 9:38 AM
OSB With Building Wrap On It (new product) mcyr Exterior Inspections 12 5/16/08 5:36 PM
