| Roofing Inspections Contains discussions about inspecting roofs. |
I have not seen this before.
Why is this roof installed this way? Is this an acceptable method? |
| Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like decorative to me
Could you explain what you mean.
It is not a decorative shingle. Seams like an improper installation. |
Single manufacturer will use it to wiggle out of any warranty issues should they occur. As long as this roof is properly nailed and all tabs are securely sealed down (Most likely some would have been done by hand) I would accept it (make sure to check the shingles at the thick overlap lines). |
Theory question.
Could not the bending in the material caused by the overlap lead to premature failure ? |
Bob I believe the dbl layer will cause a dip similar to when the starter course isn't cut down from a full shingle. I did not notice that in the pictures. But I would say you are correct.
Yeah I mean they are nailed down then forced up at maybe a angle not intended.
Correct me if wrong after all I just glanced and have not had time to think on it yet. Depends on nailing patter I suppose and unlike many here never was a roofer. |
Dave, did you ask the Seller?
There are 3 layers at the profile steps. Why every 8 courses? 40" doesn't relate to anything. Curious myself, never seen anything like it. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
[quote=dmacy;714839]Could you explain what you mean.
It is not a decorative shingle. Seams like an improper installation.[/quot no its not a decorative shingle. some people install 20 yr comp this way for the LOOK...ie decorative...See it every now and then...in my 16+ years in roofing I never have installed a 20 yr this way. It not that big of a deal... |
how could you see the starter row with out taking up the first row of shingles???? on a older 20 yr like this you would have used a full 20 yr shingle and turned it around for a starter row....imo some of you guys need to brush up on your roofing.....just my 2 cetns |
And when you turn it around instead of cutting it in half, you do not get the seal tabs to hold down the first course of the three tab and they blow off the roof on the first wind.
Applying shingles in a pattern is tricky.
It has to be laid out in a fashion as to enable its wind-shear ability( so you get no blown out shingles) along the the ability to shed water in a positive manner ( the slope is positive ) and not lesser than that of the roof its being applied to. Reduce the slope and you get ice damming in the winter. Many factors. I will try to post some photo,s of aesthetic roofing patterns. I frequent a small town and the brick and roof patterns are amassing. This one I have never seen but I have seen a variation of and hesitate to give this one the thumbs up for proper workmanship. Look at the chase and stacks. For me not well done.( flashed ) montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Here is a pic of the garage. Been patched, little mossy. |
There is the 8 strip panel again and 6 for starters.
Must be someone's idea of an asthetic design I have never seen or heard of before. Since there are 3 layers, it would tell me they did it on purpose to give it that profile. Although this roofing is showing some age from the spacing of the tabs and granule loss, I don't see how this installation would impair the functionality of its pupose. The Manufacturer may disagree, but they will find many things to deter from paying or replacing on a warranty. Interesting find David. Let me know should you find anything to that regard. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
[QUOTE=bsmith2;714872]
It is not proper workmanship. Plan and simple. Blow up the photo. Now look at the ( started strip ) used to elevate the shingle and give a 3d dimension. Look and see a void, look the the rain notch at the top shingle and the strip below it. It does not even meet. The rain notch shows a void or whole, and the shingle bellow should be carried up and under the top shingle at least 3 inches for a patten to be safe. The strip ( partial shingle being used as dimensional Aesthetic) should be carried up at least 3 inches up and under the upper shingle for weather purposes. Plus to not be such an aggressive angle. Look how the shingles have created a seam, ridge, and how were they set. Nailed at the gum strip? you cannot. it would affect the tab above.nor enought clearance. I have done dimensional at least 30 years ago. Not many and with an old roofer that is 80 pus this year. Carried his own shingles till he was 65 plus. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| Moronic door openner installation will take the roof off! | melliott1 | Exterior Inspections | 4 | 6/19/10 8:54 PM |
| Cracked shingles | pwigle | Exterior Inspections | 54 | 4/23/09 11:52 PM |
| Vegetation Roof Systems Educational by NRCA | mcyr | Miscellaneous Discussion for Inspectors | 0 | 10/14/08 4:11 PM |
| Roof vent installation | cbuell | Exterior Inspections | 26 | 1/19/06 9:52 PM |
