Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 11/29/11, 5:55 PM
Christopher Currins's Avatar
Default Asphalt shingle cracks
Sample of "cracks" in shingles I noticed at more than 5 locations at different areas of gable roof, north and south side. They all had the exact same pattern, two curved cracks, left at top, right at bottom.
Manufacturer defect? Roof covering is less than 1 yr. old, at least 2 layers, possible 3.
Pics are 2 separate locations, kind of hard to see, best I could do.
Christopher Currins
Certified, Licensed
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/29/11, 6:01 PM
James F. McKee's Avatar
Default Re: Asphalt shingle cracks
interesting how they seem to telegraph from a tab below....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 11/29/11, 6:03 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
I would say that they installed the new shingles on a windy day and they ripped along the butt in this area. This does not appear to be a manufacture defect but careless installation.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/29/11, 6:14 PM
Strange, as said all were same pattern/location at tab, but at sporadic locations at roof.
Christopher Currins
Certified, Licensed
Old 11/29/11, 6:18 PM
I've not run across anything quite like that Chris, my hunch would have something to do with the number of layers but a wag at best ...I'll be interested to see if You can come to a conclusion on this one...
Jim Mckee
Amherst, Ohio
Old 11/29/11, 6:20 PM
KEVIN WOOD's Avatar
Was there staples or nails in the attic?
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/29/11, 6:57 PM
Nails were all that were visible.
Christopher Currins
Certified, Licensed
Old 11/29/11, 7:08 PM
KEVIN WOOD's Avatar
If it OSB it can have tear off from the wind but you said it is on both sides and this creates a problem with the wind theory. Maybe Robert or Marcel have something else to add.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
That's why I posted here.
Drip edge and rake showed 2 layers. Noticed "hump" at first row indicating one layer had been removed.
This was a bank repo. The bank actually paid a contractor to fix it up a little, inside and out. It was only about 15 squares, it would have been an easy tear-off.
Christopher Currins
Certified, Licensed
Peter C. Russell's Avatar
Expansion and contraction.
Doubt you would see the MFG honor the warranty though. They would find something wrong with the installation.
The shingles contract after expanding and it tears them. Are they fiberglass?
Russell Inspection Services
New Hampshire state license # 57
Level I Thermographer, ITC
Certified Building Science Thermographer, ITC
Certified Building Analyst, BPI
Certified Commercial Inspector, ITA
Certified Septic Evaluator, GSDI #148
www.newenglandthermalimaging.com
www.russellinspectionservices.com
www.nhsepticinspection.com
Old 11/29/11, 7:10 PM
1" wood planks, built in 1950. Good condition at attic/interior side.
Christopher Currins
Certified, Licensed
Old 11/29/11, 7:17 PM
I would stay away from recommending a repair and report pre-mature failure and recommend a roofing contractor evaluate.
JMHO
Old 11/29/11, 7:20 PM
KEVIN WOOD's Avatar
1950's home with new engineered shingles might cause a problem since the whole house is moving and expansion and contraction of the planks will happen more than if it was plywood.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/29/11, 7:24 PM
JMHO
Might be a better idea.
Christopher Currins
Certified, Licensed
Old 11/29/11, 7:26 PM
Was it wide spread across the roof or isolated/
I remember a while back fiberglass shingles had a bonding problem and when it got cold out they would tear like you picture shows.
asphalt shingles remain 'best bang for your buck' rcooke Canadian Inspectors 0 9/2/11 12:15 PM
InterNACHI releases new Asphalt Composition Shingle Defect Recognition Guide. gromicko Roofing Inspections 3 5/18/11 2:53 PM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Asphalt Shingle Roof Fasteners rmurphy1 Exterior Inspections 1 3/31/09 3:22 PM
Asphalt roof shingle cracks. ngifford Exterior Inspections 2 3/25/06 11:47 PM
