| Roofing Inspections Contains discussions about inspecting roofs. |
I wanted to get some thoughts on this roof. I'm doing the inspection in a couple days and wanted to see what you all think. I haven't been on a roof with this material.
The listing agent says it is a "masonite or cement shake roof". I just want to do a little more research before I go walking around on it. These are the best pics I have of it. Built in 2008. I assume from the pic it is a concrete tile. What to look for as far as correct installation on this tile? ![]()
John Safstrom TREC #10566 Systematic Home Inspections, PLLC Allen,TXwww.systematichomeinspections.com john@systematichomeinspections.com Last edited by jsafstrom; 12/16/10 at 3:11 PM.. |
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The front facing pic doesn't look too "walking friendly" IMO
I'm looking at the pics, it looks like a concrete roof tile http://www.eagleroofing.com/products_eagleProducts.htm# to me, Masonite/woodruff... I'm not aware of any masonite roofing products being installed currently, the one's *I've* run across were "funky" to say the least and many were subject to class action suits (I think it's long enough ago the claim period was done some time back). I can tell you a home in built in 2008 doesn't have it.. But- Take a pic and post it from a bit closer when you're doing the inspection.. you'll get some feed back if you have any questions. You will be able to tell without a doubt what you've got when you're closer. Take some pics and post 'em for some feedback. I'm sure you know this, but don't walk on something you're not comfortable doing so. A good ladder and binoculars on those steep parts may be well advised. By the way... some reading for ya http://www.eagleroofing.com/pdf/Prod...tionManual.pdf Home Inspections in Palmdale Lancaster California Tim Spargo Spec Rite Inspections Commercial and Residential Inspections Palmdale Lancaster Santa Clarita CA 661-317-5770 Last edited by tspargo; 12/16/10 at 4:04 PM.. Reason: Added a link |
Thanks for the info, Tim. I agree, not very 'walker friendly'. I want to get on the back section of the lower roof to get a good look at the valley on the right. I'll put some pics up after the inspection.
Thanks for the links- much appreciated. John Safstrom TREC #10566 Systematic Home Inspections, PLLC Allen,TXwww.systematichomeinspections.com john@systematichomeinspections.com |
Have you ever walked a concrete roof before this? Do you know the proper way to way to walk this type of roof? Step wrong and you can crack the tiles. Be safe.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Thanks Nick. BTW, where do you think the plumbing vents and furnace/water heater vents are? AAV's and electric units? I don't see anything protruding from the roof.
Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 12/17/10 at 1:06 AM.. |
On a lot of high end homes and even in some planned communities here, all of the roof protrusions are in the back so as not to be seen from the roadway. Supposedly, this gives a cleaner look to the home and enhances the value. |
I figure they are in the back or on the sides where I don't have pics. Haven't been to the property yet, just asking questions off of the 2 exterior pics from the listing.
They hid the flue pipes and vents pretty well from view, although deficient
John Safstrom TREC #10566 Systematic Home Inspections, PLLC Allen,TXwww.systematichomeinspections.com john@systematichomeinspections.com Last edited by jsafstrom; 12/19/10 at 7:55 PM.. |
That sure is a nice detailed image.
Good camera work. |
| Flat Roof Inspection Question - White Color | rrunnels | Thermal Imaging, Infrared Cameras & Energy Audits | 23 | 2/27/09 7:51 PM |
| Roof question | mashburn | Exterior Inspections | 23 | 12/16/07 7:14 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
