| Roofing Inspections Contains discussions about inspecting roofs. |
While walking on the roof of a home yesterday there was an area that had a crunchy sound and feel to it. I actually found several areas like this.
I then went down to the garage below to take a look: ![]() ![]() ![]() The roof was fairly new and appeared to have a piece of sheet metal covering the hole. The buyers dad is a roofing contractor, she will have him busy! I'm lucky I didn't go thru. David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org |
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
For anyone going on roof's.
Get in the habit of looking or inspecting underside of roof first before you actually are on exterior. Just good safe practice. |
In FL, roofers are required to replace that damaged sheathing when re-roofing. That roof looks fairly new. I would refer that back to the roofer.
And yes it's code in FL to replace the rotted wood but it only happens when the home owner is watching. Definately a call out. Some one didn't have the lumber/time/money and thought they could get away with it. 5144 Atwood Terrace Inverness, FL 34452 352-212-3576
I must admit... I do roofs first because the weather patterns out here bring storms in in the afternoon. I'm more cautious around penetrations and similar hi-risk areas, like places that might have had tree-rub damage.
I don't know what the roof would have felt like on the house in the attached picture. No one knew about the fire...
I find the roof rafter and follow up to the top. I never walk the centre. The reason I do not do the attic first is the insulations fibres will be tracked all over the house. Other reason for walking the roof first is it gives me clues as to what you should be looking at in the attic. I was told by a insurance company to check the attic first. I guess I am just stupid. LOL
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Please post questions about anything having to do with roofing | kshepard | Exterior Inspections | 165 | 6/17/09 11:47 AM |
| Vegetation Roof Systems Educational by NRCA | mcyr | General Inspection Discussion | 2 | 10/14/08 5:49 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Avoiding Litigation Thread. | gromicko | Miscellaneous Discussion for Inspectors | 147 | 5/8/06 6:41 PM |
