| Roofing Inspections Contains discussions about inspecting roofs. |
I am on this inspection as I post and haven't had the opportunity to research this material. Does anyone have any experience with this Duro-Last Roofing System? I've never seen it before.
It appears to simply be a vinyl-fabric oofing material. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Sign up on AEC daily and you will get lots of info.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
You probably have this already, but heres a link for the product... http://www.duro-last.com/generalCont...investment.asp
I can get product data all day long. I am looking more for "experience" with this material - i.e. problems associated with it and longevity.
I looked over the brochure and it's warranted for 15 years. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Installation is everything especially around transitions, vents and chimneys. The other item to worry about is physical damage. Any type of overhanging tree is a potential issue. I warned a client about having a tree trimmed above his Mansard style roof with this exact product. He didn't. 1st storm and off came a branch and it stuck right through the surface. There were also leaks around the chimney. He did say that the installation company came right out and took care of any leaking areas.
In your area I would be more concerned with the 15 year life span and whether the UV stabilizers in the product can withstand the constant sun. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Thanks Steve.
The sellers had the brochure, which included some sample-material pieces. It's a two-layer system with "welded" seams. There were some buckles in the material that I didn't like, but other than that, it seemed fine. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Jeff, you might what to read a few of the reviews here;
http://www.topix.com/forum/city/sagi...K5OEA#comments LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Good reading Marcel - thanks.
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Please post questions about anything having to do with roofing | kshepard | Exterior Inspections | 165 | 6/17/09 11:47 AM |
| Vegetation Roof Systems Educational by NRCA | mcyr | General Inspection Discussion | 2 | 10/14/08 5:49 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Avoiding Litigation Thread. | gromicko | Miscellaneous Discussion for Inspectors | 147 | 5/8/06 6:41 PM |
