| Roofing Inspections Contains discussions about inspecting roofs. |
When do you think this will start leaking? House was built in an area with NO C****.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Kansas Home Inspector (and anywhere else in North America) |
impossible to tell if there is flashing behind that stone from that picture Buck , but there is obviously no kick out diverter which will eventually cause a problem imo....
The first rain after construction was completed
What flashing? Don't see one.
Pitty the poor guy that will have to replace the shingles in a few years. Is that faux stone or real stone? Any weeps? Wonder what is holding it up? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Could not see the WEEPS. The FAUX stone is covered with garden stone!!!
Could you explain LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Will leak===================___________________________ ___ Won't leak=================_____________________________ __ LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Its not when it will leak.
Its that the contractors poor construction knowledge and standards. It all needs to be redone and done right by todays building standards, practices and code requirements, period. Dave Brice CHI |
Call out lack of visible flashing, tell why it's a problem and move on.
I agree with Kenton. But shingle flashing could be cut in and a counter flashing cut in with a reglet if the stone is secure enough to take the grinder. The siding will be tougher. Did you see a "J" Chanel behind the stone. Too late to change that report I just looked at the date.lol
| Flashing wall/roof junction | bhartley | Exterior Inspections | 13 | 7/12/09 5:00 AM |
| Ledger Board Flashing | jevans | Exterior Inspections | 15 | 7/2/09 11:42 PM |
| Please post questions about anything having to do with roofing | kshepard | Exterior Inspections | 165 | 6/17/09 12:47 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| no flashing; no inspection | Leanne Jowers | Exterior Inspections | 97 | 5/9/07 1:11 PM |
