Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 8/23/10, 11:12 PM
Sean Fogarty's Avatar
Default Improper insulation causes roof sheathing damage.
Its always good to actualy see the results of poor work. This home was only a few years old and the plumbing vent was inside the small attic space.
I noted unusual wavyness on the roof, but it was too steep to walk. SO instead I pulled down a little insulation.
No air gap for ventilation because they installed it wrong, and the whole area was covered in mold. The osb was also starting to delam. Suprising enough it was not damp, but must have been at times. My foot might have gone thru if I could have walked on the roof.
I guess it goes to show you what can happen to cathedral ceilings if they can't breath.
improper-insulation-causes-roof-sheathing-damage-1.jpg   improper-insulation-causes-roof-sheathing-damage-2.jpg
Sean Fogarty
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
www.homeinspectionknoxville.com
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/24/10, 12:20 AM
Tom W. Leahy Tom W. Leahy is offline
Default Re: Improper insulation causes roof sheathing damage.
Sean, just to make sure I understand what happened here, no vent baffle was installed between insulation and roof deck, blocking the soffit vent. Plumbing vent terminating in attic and put it all together and you get this mess.
Looks like you went beyond SOP and pulled the insulation down to get the visual you needed.
Good pics, Thanks
Fort Worth Home Inspector
Dallas Home Inspector
http://leahysinspections.com/
Old 8/24/10, 8:39 AM
You are correct. If the whole roof is this bad I just saved the buyer thousands of dollars by going beyond the sop.
THe houses on either side of me had the same noticable roof wavyness.
All rental cabins.
Sean Fogarty
865-256-5397
Old 8/24/10, 8:50 AM
Wayne B. Wilson's Avatar
Good find, just another example of fine unsupervised workmanship. No building inspector in that area till a couple of years ago.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 8/25/10, 8:12 AM
Banned
Correct the 2 much larger flaws in your pictures, the continuous moisture source of the open vent and the cathredral ceiling insulation with NO ATTEMPT AT AN AIR BARRIER, and the moisture problems on the sheahing will disappear. Adding ventilation to this setup after correcting the vent situation will increase energy costs!!
Old 9/11/10, 10:38 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
They make baffle vents for that very purpose.They work great.I see more and more of what you are showing me and home owners screening at high energy bills.They do not realize there roof is degrading.Once the problem is solved it a much lower energy cost and a dryer environment.
No gabble end vents?
Old 9/11/10, 11:13 PM
No gable vents. No room with the style of ceiling
Sean Fogarty
865-256-5397
Old 9/12/10, 6:02 AM
Sorry Sean.I understand Sorry I did not read you where in small attic space I just surmised by the pics it was gambrel. . I assumed,Man I walked into that one.Any vents at all to release the moisture?
Old 9/15/10, 5:12 PM
1. A plumbing vent should terminate at the exterior to prevent sewer gas from entering the living space, not because it's a big source of moisture.
2. That's an attic space, not a cathedral ceiling. The insulation should be installed in the floor, not between the rafters and the attic space vented to help keep the roof cooler.. Basically, with no attic venting and insulation installed between rafters, the attic is part of the conditioned space and should have a minimum of 3.5 air changes per hour, just like the rest of the living space, to prevent moisture levels from becoming too high.
3. In cathedral ceilings, the air space created by the baffles is to cool the roof and help prevent premature failure of the roof-covering material, especially comp shingles, due to excessively high temperatures. Moisture is a separate issue.
4. Heat wouldn't make OSB delaminate, but moisture would. The source of moisture should be found and corrected.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 9/15/10, 6:27 PM
Joe Funderburk, CMI's Avatar
I agree. The insulation on the sheathing is improper. They've created an "unventilated attic". The IRC addresses unventilated attics and this one is definitely wrong. The insulation on the roof sheathing is supposed to be closed cell foam and there should be no insulation on the ceiling, if that's what they were trying to do. FUBAR.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/15/10, 6:47 PM
I'm leery of the closed cell foam on the underside of the roof sheathing.
If the roof leaks, how will the occupant know? The leakage won't be able to get past the foam and will be absorbed by the roof sheathing, which will decay quickly if it can't dry to the inside and dries only slowly to the outside.
Also, heat will dissipate more slowly, since the roof can't dump heat to the attic. This may cause comp shingles and underlayment to fail prematurely.
(303) 717-8940
Old 9/15/10, 11:53 PM
I'm with you 100%, but that's what it says.
Theodore Roosevelt
Joe Funderburk, CMI
Old 9/16/10, 12:02 AM
Yep, certain factions of the green building movement have been promoting it. Great ideas aren't always great ideas.
(303) 717-8940
Old 9/17/10, 6:52 AM
Thank you Ken. I was totally confused by the pic,s. They are not explaining as to what is being described to how the roof would look as a cathedral ceiling.I should have pointed this out to hm in the first place.
Thank you for your observations.
You are right in all your observations and conclusions.
Robert Young's
Montreal Home Inspection Services.INC
InterNACHI + ACHI CERTIFIED ( CPI ) ( CHI )
REGISTERED INC. E&O INSURED
RESIDENTIAL BUILDING INSPECTOR
http://www.montreal-home-inspection-services.com
http://www.home-inspection-montreal.ca
http://www.homeinspectionmonteal.com
Newer roof with wet sheathing jbraun General Inspection Discussion 9 3/6/10 8:53 AM
Insulating Your House from CMHC mkyriacou Canadian Inspectors 10 2/14/10 4:50 PM
Cracked shingles pwigle Exterior Inspections 54 4/24/09 12:52 AM
Isomere insulation and roof ventilation hvanderbeek General Inspection Discussion 5 3/10/06 3:36 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 4:38 AM
