Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 11/13/11, 12:10 PM
Dave Penta Dave Penta is offline
Please Note: Dave Penta is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Inspecting Spray Foam Roofing Details
One of the most over looked details when it comes to spray foam roofing is call a V groove detail. A V groove is where the SPF system terminates to the gravel stop edge. It is installed by removing the spray foam from the lip of the gravel stop typically using a razor knife and then a 45 is cut to create a V. The V is filled using a urethane or silicone calking (Pending the UV coating system installed over the foam). The reason this is needed is to create an expansion joint between the metal and the foam. If not installed correctly, the metal expands and contracts through out the day. The foam is an insulation there for dose not. This will cause a split over time in the system. When installing a V grove it is important that all of the foam is removed from the lip's edge. I would like to hear and see photos form inspectors that are currently inspecting Spray Foam system. For more infomation on spray foam, spray foam equipment and spray foam rigs, contact SprayWorks Equipment Group.
asphalt shingles remain 'best bang for your buck' rcooke Canadian Inspectors 0 9/2/11 12:15 PM
Foam Roofing gdelaney General Inspection Discussion 1 8/6/11 12:08 PM
ESOP's decision supported by mathematical analysis. gromicko Canadian Inspectors 57 12/5/09 12:30 PM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
