| Roofing Inspections Contains discussions about inspecting roofs. |
What do you think the slope of this lower roof is?
The builder says its within the range where 2 layers of 15 lb felt can be used under the shingles. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It may be OK See this mfg. recommendation for installation on low pitch roofs. http://www.iko.com/misc/CasmaPdf/16-LowSlopedRoofs.PDF Quote:
Make sure they dump the upper gutter on the lower roof (like they do around here) and see what happens!
Wonderful job security! "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
In order to achieve fire-resistant ratings (Class A or C), an underlayment must be used regardless of the type of shingle being installed.
A minimum of 2 layers of felt or 60lbs of base (2 layers of 30lb) is required for roofs with slopes less than 4/12. In such cases, the application must meet the requirements for low slope roofs. Alternatives for 2 layers would be 1 layer ice and water shield. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
In most cases it's not only the additional felt, but it's also in the modification of the shingle exposure. Reducing the shingle exposure can result in a so-called "triple coverage".
I've done this on several projects and have never had an issue. Many manufacturers explain this process in their training manuals. But again, I'm in the land of not having to deal with "ice dams". |
2006 IRC code
R905.2.2 Slope Asphalt shingles shall be used only on roof slopes of 2 units vertical in 12 units horizontal (2:12) or greater. For roof slopes from 2 units vertical in 12 units horizontal (2:12) up to 4 units vertical in 12 units horizontal (4:12), double underlayment application is required in accordance with Section R905.2.7 Look up 2009. May have changed. International Residential Code (IRC) 2006 | Section R905 http://www.lsuagcenter.com/NR/rdonly...odeHIGHRES.pdf montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
The simplest solution would be to install a standing-seam metal roof over it. Many (not all) metal roofs are fine at a 1:12 pitch pitch or even less. Snap-Loc 24 can be installed at a nearly-level 1/4:12 pitch!
Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 10/15/11 at 2:31 AM.. |
Less than 3 in 12
Low slope materials required... If he can convince a Municipal Building Inspector to accept (Which it appears to be) what is the question? ? Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Another issue: It appears the builder ran out of StraightFlash (the correct product to flash the top and sides of the windows when using a house wrap)...and switched to mere Tyvek seam tape to flash 3 of the windows. This is incorrect.
Optimally the sills would be done with FlexWrap, but a roll is really expensive (I bought a roll today Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 10/15/11 at 3:13 AM.. |
John Mathew is a non-member guest and is in no way affiliated with InterNACHI or its members.
You can check with Tradition Roofing & Exteriors. Who are in roofing & exteriors for more than 15 years providing quality work and excellent customer service.
Bruce,
If this is NC then check the NCRC and go from there because that is all the builder has to conform too....that and the manufacturer which will ultimately state to adhere to local and state codes. |
Hard to say for sure. I'd put it in the report, make the buyer aware of the requirements and put the burden on the builder to prove it is greater than 2 in 12.
Nice observation oh great one. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
I basically reported this during a predrywall inspection as irregardless of actual measured slope or code, this will leak over time if proper low slope methods are not installed. The buyer and I convinced the builder to do what I rcommended and they did!
Sometimes the code angle will hurt your client since the builder can refuse to do something if it actually meets code. Many roofs like this will meet code and leak. I guess I just have the right way of communicating because I get lots of things done for my clients. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
| Built Up Roof Narrative | jscaparo | Roofing Inspections | 20 | 7/2/11 1:18 PM |
| Retro Roof Area and Slope Calculator | edeandres | Florida Inspectors | 0 | 6/12/11 3:20 PM |
| Please post questions about anything having to do with roofing | kshepard | Exterior Inspections | 165 | 6/17/09 11:47 AM |
| Roof deck question | wdecker | Exterior Inspections | 3 | 11/17/08 10:17 PM |
