| Roofing Inspections Contains discussions about inspecting roofs. |
I'm not that familiar with steel roofs. This valley is in a transition from a steep to a low slope area. It appeared that run-off from the steep slope would over shoot the valley and drive water under the panel on the opposite side of the vally. There was a lot of sealant used in some areas and none in others plus the thru bolts were rusted. Would there be a gasket under the panel at the valley to stop water intrusion?
| Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Marcel I think it would be easier just to say it is all wrong! LOL
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
That is basically what I was saying. Just showing details of how it should look.
Wrong big time, no doubt. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
What's the wrongest part part about it?
Not asphalt .
I see bad insulation with Asphalt shingles . Here I see most steel roofs are very poorly installed . Steel in Canada costs about 3 times steel . Most people do not stay in a home long enough to get the reward of the steel life Steel covered roofs Homes sell for the same price as a steel covered roof , so why invest the extra cost when reroofing ..... Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Marcel has pointed out the proper install info you will need to go from the top to the bottom.
Flashing is wrong for Chimney and plumbing stack. Flashing is wrong in the valley. No end protection. No stand off. No over lap. Off set on the ridge. Penetrations in the wrong area ect,ect,ect. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
to many beers on this one....lol...needs some work rec roofer to inspect and repair/replace
| Metal roof add-on | acox | Roofing Inspections | 2 | 9/11/10 9:33 PM |
| Metal Roof over composition aspalt shingles | afaghih | General Inspection Discussion | 9 | 8/23/10 10:10 AM |
| question??? Metal roof sweating | mjohnson6 | Exterior Inspections | 6 | 2/16/08 12:45 AM |
| Moss growing on roof | ecox1 | Exterior Inspections | 45 | 1/19/06 9:57 PM |
