Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 11/4/10, 2:40 PM
David C. Macy's Avatar
Default Miss aligned shingles
12 years old shingles, 1 layer. Miss-aligned shingles at portions of roof surface. Seems like a fastener issue or poor workmanship?
Observed numerous nail pops and improperly located nails.
Just curious on your opinions of the miss aligned shingles
Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/4/10, 4:02 PM
Default Re: Miss aligned shingles
Most roofers employ the stack method of installing shingles verses stepping.
Many if not all manufactures warn against using the stack method, mostly for aesthetic reasons however the majority of installers make their money by the number of squares they can install......stepping takes more time but produces a better result.....especially with 3 tab shingles.
Simply annotate same on your report, explain same to your customer as well as advise them as to what manufacturer recommends (if you know who the manufacturer is provide installation instructions)
Jeff
Old 11/4/10, 4:25 PM
Those shingles are installed using the racking method. It's required for a few models, permissible but not preferred by others, and not allowed at all by some. The gaps are excessive.
Recommend evaluation by qualified roofing contractor.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/4/10, 4:41 PM
I did recommend a roofer as there were other issues as well, like nail pops, improper fastener location, missing step, counter flashing, prior repairs to flashings with stains, patches below.
I just wanted to inquire about the shingle alignment.
By the way excellent roofing course from Nachi TV Performing a roofing inspection part 1. I downloaded the PDF and it has info on the racking as you guys stated.
I believe these are Certainteed Shingles.
Thanks!!
Old 11/4/10, 4:44 PM
Those are laminated/architechural shingles. I don't believe racking is ever approved by manufacturers. They, specifically, show application method and offset on the package for best appearance and to avoid damage from over bending the heavy shingles.
Larry Kage, CMI
231 929 3525
Old 11/4/10, 4:51 PM
Larry, I was looking over the Certainteed shingle applicators manual and you are right one about the racking.
Old 11/4/10, 4:59 PM
CertainTeed recommends using the racking method on Grand Manor, Carriage House and Centennial Slate models. Applicator's manual pg. 150
(303) 717-8940
Old 11/4/10, 5:08 PM
Thin, huh?
COMPLETING COURSES:
On alternating courses where the right-hand shingle end was
purposely left unfastened, carefully lift the loose shingle end, so
as not to cause damage by tearing or sharply bending, especially
at the top of the cutout tab “keyway,” and slip the next shingle
underneath to butt the hidden shingle end.
Larry Kage, CMI
231 929 3525
Old 11/4/10, 5:23 PM
thin?
Oh. Yeah, doesn't seem like the greatest idea. Sometimes the roofers "forget" to go back and finish nailing.
(303) 717-8940
Foam Insulation Requires roof Ventilation dvalley Thermal Imaging, Infrared Cameras & Energy Audits 30 9/4/10 2:43 AM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 12:21 AM
