Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 10/16/13, 9:19 PM
Michael A. Clark, CMI's Avatar
Michael A. Clark, CMI Michael A. Clark, CMI is offline
Default Radiant Barrier?
This appears to be a sort of foil radiant barrier in the attic of a 1949 house. 90% of it has crumbled and fell to the attic floor. My thoughts are that it trapped moisture because there are no vented soffits and no ridge vent, yet moisture levels in the attic were not excessive.
Does anyone know if this stuff is, in fact, a radiant barrier, and if so, is it really a defect since it's not required, and because most of it is crumbled to the attic floor?
Michael A Clark, Certified Master Inspector«
Inspection Connection
St Albans, West Virginia
"Always tell the truth,
do what you say you will,
and do it Righter than Right...Always"
Facebook
Google Plus
www.charleston-home-inspector.com
www.icwvhomes.com
[email protected]
Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/16/13, 9:24 PM
Jeffrey R. Jonas's Avatar
Default Re: Radiant Barrier?
Since 90% of it is now laying on the floor, it is no longer serving it's intended purpose, so... defect.
Or, the alternative is that 10% of it jumped up off the floor and stuck to the attic ceiling!
[email protected]
Old 10/16/13, 9:59 PM
haha..very true, and sounds like my line of thinking, Jeffrey!
I won't recommend it be re-installed at all, unless they put a ridge vent in to let the hot air escape, and Since the shingles need replacing, it would be a great time to do it.
Facebook
Google Plus
www.icwvhomes.com
[email protected]
Old 10/17/13, 6:43 AM
Eric C. Van De Ven Eric C. Van De Ven is online now
They sure did it the hard way!
I would probably say something to the effect of, radiant barrier was not installed properly as evidenced by the fact most of it is no longer present!
Was there anything inside of that foil?
Old 10/17/13, 12:30 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
Location: Cuernavaca, Morelos, Mexico, (from Boulder, CO)
Old, poorly-installed radiant barrier has failed and should be removed. Replaced at the owner's discretion. Lack of rafter bay ventilation will void shingle warranty
Kenton Shepard, CMI
Director of International Development
Director of Green Building
EXPERT WITNESS SERVICE
www.hinarratives.com
052 777 246 4676 (preferred)
052 777 154 5451 Cell
INSPECTION SERVICES WORLDWIDE
Old 10/31/13, 4:39 PM
sammy bean sammy bean is offline
Please Note: sammy bean is a non-member guest and is in no way affiliated with InterNACHI or its members.
Those old forms of radiant barrier were foil faced sisal paper. That stuff just doesn't last very long . Makes for good packing tape though!
radiant barrier question jcahill Roofing Inspections 3 3/27/13 9:13 PM
OSB roof decking (LP TechShield Radiant Barrier) lfreeze Structural Inspections 4 12/27/06 9:40 PM
