| Roofing Inspections Contains discussions about inspecting roofs. |
Anything to prohibit that or should the shingles/shakes have been removed?
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
you're joking right?
Wasn't there a discussion here a few weeks ago about this? I could of swore you were part of it.
http://www.nachi.org/forum/f16/more-...al-code-61246/ You supplied the answer. Now you question it? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Wow, that's pretty bad. Call your local building department and ask them. If a new roof was put on they should have had a permit right?
My question in this thread is, can you hang your hat on anything that says a new roof decking over wood shingles or shakes is wrong. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
From the other thread... Quote:
The way I read that code, is that it prohibits the installation of asphalt shingles directly over other types of shingles in certain situations.
My question here is, again, is there anything that absolutely prohibits the installation of OSB sheathing on top of wood shingles or shakes. In that case, the subsequent layer of asphalt shingles would not be a direct installation over the wood shake/shingle. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I'm done here. Next! Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
The same reason multiple layers of asphalt shingles are not allowed is the same reason sheeting should not be put over shakes. The answer is: The roofing material has to breath.
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Also weight and fire issues.
Usually the problems are attachment of new shingles adequately to the wood sheathing, extra weight on framing, curled/clawing old shingles not providing a flat surface for shingles to lay flat and seal down. |
Besides the extra weight, I see the primary issue being that there is no way to ensure that the sheathing fasteners actually hit the structure. The nails might simply have been driven into wood shakes/shingles. How would the guy driving the nails know what he hit? The right kind of wind, and it's all gone.
I don't need no code book to tell me that installing a roof sheathing on top of wood shakes is wrong or right. It is totally assinine.
How in the world would you maintain a smooth plane on the roof on top of wood shakes. Those are hand split and none are of the same thickness. Now I know there are idiots out there that would do this type of work, but that is because they do not know anybetter. And the way the code is written, should cover this type of overlay on an existing roof. Like Jeff said, the intent of the code is clear to me to prevent this, plus the AHJ would have the last word on this with a permitted work. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Agreed. If someone told me it was OK, I still wouldn't hang my hat on it. At best... a lumpy, unprofessional mess. At worst, an over loaded, deficient roof installation. |
If an engineer ok's it, I'm good. But you won't find an engineer dumb enough to ok that.
https://www.facebook.com/StateCollegeHomeInspector http://www.centreinspection.com Centre Inspection Services proudly serves the following towns; State College, PA 16801, Bellefonte, PA 16823, Centre Hall, PA 16828, Spring Mills, PA 16875, Millheim, PA 16854, Boalsburg, PA and the surrounding areas. |
| INACHI Technical Library | bkelly2 | Miscellaneous Discussion for Inspectors | 16 | 6/18/10 10:45 PM |
| Roof deck question | wdecker | Exterior Inspections | 3 | 11/17/08 10:17 PM |
| Check The Deck | wdevries | Canadian Inspectors | 1 | 7/9/08 2:00 PM |
| Preventing Moisture related Problems | mcyr | Ancillary Inspection Services & Additional Topics | 1 | 12/19/07 8:30 AM |
