Roof experts: I inspected this house last week, new roof. I have never seen the ridge cap done like this. In my opinion the wind could easily blow the ridge cap off. I recommended a qualified roofer evaluate and replace.
What do you think? ![]()
David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org |
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
David, I have never seen anything like it and don't know how it would be possible to bend composition shingles like that without breaking the asphalt surface.
LEED Green Associates Inachi US Member of the Year Award 2009 Best Home Inspector Software http://co.nachi.org/inachiawards |
IMO this installation wouldn't allow the caps to properly bond to the adhesive strip.
Christopher Currins Certified, Licensed Providing Quality Home Inspections In The Metro East Region Of Southern Illinois We Make It Safer |
Wow....how hard some will work to avoid working hard and doing it right.... Amazing
http://www.eagleseyeinspect.com george@eagleseyeinspect.com George Skeeters Eagles Eye Inspection Services Shelbyville, Kentucky |
I have never seen anyone do that before. Defiantly not done as per manufacture recommend install
change it now while they can get a shingle match...that will not last long I spect....
These ridge caps are manufactured this way. The idea is that they cover the fasteners with the fold.
Just as with the field shingles, there is usually an "adhesive" strip that will seal the fold against uplift. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Jeff have you got a link for this as this is not done here in SSM?
THE RIGHT TRAK CIAQP, IAC2 Board Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq apoteyes@gmail.com Cell: 705-971-2096 Ph : 705-946-2676 |
Used to seeing hip/ridge caps just a bit different, but they may just be Certainteeds.. http://www.certainteed.com/resources...RidgeBroch.pdf
well I'll be ...something new everyday.....
Yes but I would prefer this http://www.gaf.com/Roofing/Residenti...s/Seal_A_Ridge for normal shingle application however if you are looking for high profile interlocking is the way to go. I just have not seen the need for this here yet.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 2/8/13 at 11:08 AM.. |
I will look for this but I don't think I will ever see it here Jeff.
avoid hard work? looks like they added work and still did it wrong.
Mike Auger R.I Home Inspector NACHI Certified Home Inspector IAC2 Certified Rhode Island Home Inspection Service RI # 32856 (401) 578-4878 A U.S.A.F. Veteran Owned Corporation
How is this wrong Mike?
| Ridge Cap Shingles over Ridge Vent | rmayo | Roofing Inspections | 18 | 1/8/13 12:12 AM |
| Ridge Beam Question | rmarton | Structural Inspections | 24 | 2/13/12 7:47 AM |
| Closing Gable Vent | Kevin Patteri | General Inspection Discussion | 26 | 11/8/10 10:30 AM |
| Ridge and rafter issues/shed dormer | Adam J. Deangelo | Structural Inspections | 1 | 5/16/08 3:30 PM |
