What do you all think of this new roof?
John Shishilla State of Florida Licensed Home Inspector #21 Residential Contractor Accredited Claims Adjuster (ACA) Mold Assessor MRSA 1544 President of Fl Home & Insurance Inspectors Chptr VP of Nachi Managment Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas. Honor Construction Inspection Service www.honorconstruction.com "Because details matter" 321-327-2950 |
| Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
haha.
Same ladder and roof from my last inspection. |
I carry a 13' and 22' with me all the time. The 22' is heavy and I usually use the 13' even for two stories. Not the smartest of things to do with your day. I would like the 15' fiberglass version but really do not want to spend the money on it.
http://www.littlegiantladder.com/lit...iberglass.html John Shishilla State of Florida Licensed Home Inspector #21 Residential Contractor Accredited Claims Adjuster (ACA) Mold Assessor MRSA 1544 President of Fl Home & Insurance Inspectors Chptr VP of Nachi Managment Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas. Honor Construction Inspection Service www.honorconstruction.com "Because details matter" 321-327-2950 |
Its hard to see but there appears to be air pockets in the roof and is it improperly installed it appears the first row overlaps the second row, and should be the opposite. Meaning the closest to the end of the roof should have been installed first it appears to have been installed last giving the overlapping a reverse effect.......But the picture is not all that clear.
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
I was looking at the multiple air pockets
I see better in the 2nd pic. If this is REALLY new then I see this all the time. Seems to take a bit of our heat to get it to lay down properly. If I see this I check all seams and ensure they are nice and tight...if they are small pockets they don't bother me. John pic 1 top right side is there a gap at the drip edge area that would be susceptible to uplift during high winds? Seems like the air pocket is exposed.
Is it rooled roofing or torch down?
If its rolled then its jsut crap and should be called out as such, but it looks like torch down. If its torch down, then your going to get some waviness. There should be 42# paper underneath that is nailed down with metal caps, so I would not find any issues with a few air bubbles, or wrinkles. The change in weather will cause expansion and contraction. As long as the edges are secured well to the drip edge then it should be fine. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
I guess Russel beat me to it. I put that type of roof on my home after hurricane Jean. As long as the paper is down good and tight, once the membrane is heated up and stuck, it wont come back up. THe cool thing with that roof is, if you ever get a hole in it, you can just take a small torch up there and melt the hole back closed.
Snakes. They roofed right over a buncha' snakes.
Im with Kenton.
I see this all the time on low slope roofs, that is a common problem with this material. You can no longer buy it in my area, I was told once that they no longer made it. |
It almost looks like they went over the old roof covering. You shouldn't have those wrinkles.
On other types of installations, I have seen a large weighted roller used to get everything flat. |
Normally this type of roofing is installed with weighted rollers being moved back and forth on the rolled out ply to insure no air gaps.
Also rolled to insure good bonding in the 3 to 4 inch lap joint that ad-tears them to form a membrane. Not many practice this method for application of cold roll style roofing,and results in blister and air pockets are the results. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
Modified Bitumen (torch down) buy it all day long and if installed correctly they are very good roofs...getting ready to do a 3 ply one next week |
roof is a Modified Bitumen (torch down) roof as long as it was installed correctly it should be ok…what happens if these rolls sit too long they get these wrinkles in them. If the installer does not let the material relax before torching it then this is your result….to me it looks like they only torched the seams of the material…I prefer to torch the hole roll…bottom line looks like this guy rushed this job and did not care about the appearance. You should check and see how the edges were installed that is also a key on torch down….
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 2:59 PM |
| Before You Start Repairing or Replacing Roof Finishes from CMHC | mkyriacou | Canadian Inspectors | 0 | 9/17/09 12:52 PM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
