| Roofing Inspections Contains discussions about inspecting roofs. |
Inspected a roof today. Deck was 7/16 plywood and could only find 1/2 inch shiners, they looked like D common nails. Would they really use 2D commons to attach a deck for a house built in 1988 ?
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Would like to see a picture of the condition you describe, but I think you are most likely looking at the penetration of a 1-1/4" roofing nail used too attache the shingles. You should take a moment and go too the control panel and fill out you profile so that the members of this forum will know what area of the Country you located as many topics are regionally specific Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
It sounds like your question is "Would they really install something improperly?" To which the answer is, "Yes."
Thanks Mark & Jeff I went back and scanned the entire attic. I finally found a couple staples sticking through a truss. They were 1 3/4 total length. Whoever stapled did a tremendous job I only found five or six in the whole attic.
| Rock Lath Roof Deck | mmeeker | Florida Inspectors | 15 | 10/22/10 6:32 AM |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 10:50 AM |
| Please post questions about anything having to do with roofing | kshepard | Exterior Inspections | 165 | 6/17/09 11:47 AM |
| Check The Deck | wdevries | Canadian Inspectors | 1 | 7/9/08 2:00 PM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 2:05 PM |
