Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 10/3/11, 7:35 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Roof looks good...upclose I dont see flashing...Need advice
Roof looks like its in good working condition from all angles.
No signs of water penetration anywhere...Attic, Garage rafters
inside of the house etc....
Up-close where the fascia meets the roof....I dont see flashing.
I see the edge of the plywood. Is this an acceptable form of construction?
An Ounce of prevention is better
than a pound of cure :}
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/3/11, 7:41 PM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Roof looks good...upclose I dont see flashing...Need advice
If the shingles overhang at least 1-1/2", there shouldn't be any issue. Any less drip-edge is required as opposed to recommended.
Old 10/3/11, 7:43 PM
Stephen W. Stanczyk's Avatar
Even in this rainy climate, I very seldom see drip edge or rake edge flashing. I always recommend it but it is still rarely installed.
They finally started to learn that the OSB sheathing was 10x more susceptible to moisture so they use plywood for the exterior 2' of sheathing. It should still have the flashing.
Stephen Stanczyk
Old 10/3/11, 11:13 PM
Thanks Steve...
Old 10/4/11, 11:03 AM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
so what happens lets say in 5 years time the osb/plywood has sucked up water and is now dry rot....think about that for a sec???
what about your roof to wall area? from your pic I do not see steep flashings but could be hard to see from the pic...make sure your r to w area has flashing and is not just sealed with caulking...
Old 10/5/11, 4:53 PM
Pete Campbell's Avatar
Pete Campbell Pete Campbell is offline
No! There is no drip edge installed. And therefore there is probably no rake edge flashing installed either.
Keep looking and looking and looking. When you go up your ladder you naturally check this 1st. Then, did they use a starter course? Is the bottom course sealed down? And off to the races you go. Such a basic error at the very beginning of the job is usually a good indicator of lots of other problems and maybe a 'drive-buy' AHJ inspection.
Pete Campbell
pete4545@comcast.net
http://www.PortStLucieInspections.com
http://www.ChooseGI.com
http://ifwemissitwewillfixit.com
Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida.
Old 10/5/11, 4:59 PM
What are you talking about?
Take a look at some roofs in Richmond after the 'cane. Shingles should NEVER 'overhang at least 1 1/2"! They should be sealed down tight and flush with the drip edge. I have never seen Roofing MII that allowed such a overhang.
Put a 100 mph windload on your 'overhang' for an extended time period and see where the shingles end up in the next zip code.
Pete Campbell
Old 10/5/11, 5:51 PM
http://video.search.yahoo.com/video/...ping+Water.3GP
http://www.youtube.com/watch?v=wPTec_tIyCQ
contractor claims I don't need roof flashing by dorm windows??? Scott Csaszar Roofing Inspections 4 6/27/11 11:04 PM
Step flashing on roof overlay jgromkoski Roofing Inspections 24 3/17/11 7:28 AM
Floating flashing or sinking roof sfalvey Exterior Inspections 15 11/14/08 9:17 PM
Good Reference for Wood Shake Roof krichardson Exterior Inspections 5 1/17/06 6:59 AM
