Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 11/4/11, 1:17 PM
Bob Elliott's Avatar
Default Roof valley
I am wondering how to comment on this valley.
What causes the edges to look this way as it is a newer roof.
Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/4/11, 1:23 PM
Roy D. Cooke, Sr's Avatar
Default Re: Roof valley
Looks to me like an improper installation .
I think should of had woven shingles or a metal valley with a folded barrier .
Be interesting to see what the experts say. Is there lack of flashing at factia to the left also
Old 11/4/11, 1:33 PM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Lack of attic ventilation??
Old 11/4/11, 1:36 PM
Dan Curtin Dan Curtin is offline
Poor intall, looks like they didn't the shingle from the dormer thru far enough, then probably gobbed a bunch of plastic cement under the edge. Looks like they did the same thing on the ridge cap on the right. Also did a poor job of cutting the valley. jmho
Old 11/4/11, 1:37 PM
I see offset valleys around here but this one does not look right.
Metal flashings are usually on the McMansions with standard weaves the more common.
Old 11/4/11, 1:38 PM
3 roof vents/no soffit but I could feel the air circulation and this one was just rehabbed.in the last month.
Old 11/4/11, 1:40 PM
Yeah that is kinda what I am starting to think and the front flashing is really patchy with no kickouts.
Just looking for report lingo on the valley to state my concern as it appears the water could push up and under.
Anyone have a good illustration of proper way to do the offset style?
Should I push to have a I recommend a licensed and certified Roofer examine. come out or just opinion it as a /monitor/ on the valley?
Old 11/4/11, 1:56 PM
That's a tough one, it will prabably last a few more years, should monitor for sure. How old do you think it is? Too bad, they did a really sh!tty job, the valley, ridge, they don't lay fleat anywhere.
Old 11/4/11, 2:22 PM
I reported that the cuts were poor and combined with the flashing (lack of) at the plumbing vents and front roof/wall flashing(no kickouts) was enough.
Old 11/4/11, 2:44 PM
Christopher Currins's Avatar
Basically a sloppy job/cut.
http://toolbelt.buildiq.com/media/20...glepostsbs.pdf Page-2
Christopher Currins
Certified, Licensed
Old 11/4/11, 3:20 PM
Originally Posted by ccurrins View Post
Out to inspect but I saved that as a nice little index card type PDF for refresher reminder use.
Put on G doc and you can view from the phone.
Old 11/4/11, 4:28 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
I have seen this before. The roofer probably went over the rusted valley flashing. Generally they will tar and goop it first and then run the shingles over to the other side of the valley. This will work for some time but eventually moisture will get under the edge and run under the shingles to the existing valley. It is next to impossible to get a good seal with the shingle and tar bond on this kind of valley.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/4/11, 5:54 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is online now
Is there a wood shingle roof underneath the COMP shingles?
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 11/4/11, 7:48 PM
We use asphalt comp and metal valley flashing's are rare around here.
You think we are in Hollywood or what?
Not sure I have even done a wood shingle roof...maybe once.
Old 11/4/11, 8:19 PM
Only see wood shakes here on high end homes.
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 10:50 AM
Cracked shingles pwigle Exterior Inspections 54 4/23/09 11:52 PM
Valley bhartley Exterior Inspections 2 11/3/08 7:55 PM
Avoiding Litigation Thread. gromicko Miscellaneous Discussion for Inspectors 147 5/8/06 6:41 PM
