| Roofing Inspections Contains discussions about inspecting roofs. |
An investor that I have inspected several properties for recently had 6-8 of his properties re-roofed with 20 yr, 3-tab, asphalt shingles (probably Owens-Corning but that is to be determined). All properties are 4:12 to 6:12 slope. Before he proceeds with other properties, especially a large apt complex, he would like an independent opinion as to the installation quality of the roofing contractor he is using. My plan is to use the attached checklist for each property to judge the installations. Are there other items I should include? FYI, I'm in central Texas therefore ice/snow protection is not an issue.
Roof checklist.pdf |
Maybe add the shingle style...3-tab 20yr. .....architectural..?
I might include style of roof, type valleys but otherwise it looks pretty inclusive.
Proper nailing, not over or under driven (just below tar strip) Proper shingling at penetration flashing (lower shingles go under flashing) …and here are reference sites: http://www.hammerzone.com/archives/roof/maintenance/reshingle/install_1/asphalt_1.htm http://www.certainteed.com/CertainTe...tion/Shingles/ InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
All great inputs...I'll add/change the checklist to include those suggestions.
One other note...as I was looking at the Owens Corning warranty and talking to a guy at Lowe's ( I know, I know....that's why I'm asking here Last edited by mboyett; 1/5/08 at 5:19 PM.. |
I would add roof penetrations such as plumbing stacks and how they are flashed, also what about skylights/flashing?
But in most cases it is not a case of is it going to leak but when is it going to leak. ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
You can market these credentials to others in your market which will differentiate your services. check out www.moisturefreeinspections.com |
Michael,
Nice doc. overall Does red X mean repairs required and green Check mean OK (identify)? I break attic venting into categories soffit, static roof, turbine, gable, and continuous ridge and note location and number of units present. Usually take an identification photo or embed diagram of each type too avoid calls. You're probably aware of this from TDI, may or may not apply to location or what their expectations are of you http://www.tdi.state.tx.us/wind/docu...Revisions1.pdf I would also furnish my client this info if project(s) require so they can coordinate with the roof contractor http://www.dryflekt.com/ Around here on re-roofs it is common for guttering to be removed, disconnected, altered, misaligned or damaged. Would this lie within the scope of your work? If not is this spelled out? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Thanks for the input...I appreciate it. Last edited by mboyett; 1/6/08 at 12:22 PM.. |
Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
The NRCA makes a statement that Plywood is preferable due to concerns with OSB longetivity, but does not specifically exclude its authorized usage.
As far as shingle manufactureres, they either defer to the APA, NRCA a or ARMA in generalities. Many warranty issues seem ambiguous, and may be open to interpretation, conveniently to suit the manufacturers preservation and not the shingle warranties. Ed |
http://www.pws.gov.nt.ca/pdf/publica...-Checklist.pdf ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
Since you include a determination if the shingle is porperly fastened to the deck I'd probably put a line identifying the slope since proper fastening is effected by a regular or high slope comnditon.
But it looks like a firly decent checklist. Already filing the serial numbers off for my files. Thanks |
| Asbestos | jlybolt | Exterior Inspections | 41 | 7/17/07 1:13 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| NACHI Chicago Education Meeting - Roofing | wdecker | Inspection Education & Training | 0 | 10/5/06 11:03 PM |
| Masonite Woodruf Roofing | reborn | Exterior Inspections | 3 | 3/10/06 10:45 AM |
