| Roofing Inspections Contains discussions about inspecting roofs. |
The fasteners used on this ridge vent are very rusted. Not sure they're allowable, but in my opinion they will fail in the next few years. Also the flashing of the electric service mast looks improper. My feeling is the rubber boot should not be exposed to the UV like it is. Posting this for any feedback you guys may have - thanks in advance
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like the Boot Flashing is missing the Metal portion, and ring-shank hot dipped Gal. Nails should have been utilized.
I wouldn't make it sound like the end of the world, simple 30 min. repair. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I call this out all the time. A lot of builders say it's not an issue, but it can and will lead to a future leak.
"exposed nail heads were observed on the roof surface; all exposed nail heads need to be sealed to prevent moisture intrusion or leaking". |
Those look like three tab shingles . If they are the whole roof job looks like an amateur mess . If you would notice the tab alignment . I say It don't look acceptable and should be looked at by a qualified roofing contractor .
galaxyhomeinspections.com An amateur built the Ark ! Professionals built the Titanic ! |
Thanks for the input guys.
| Electrical service question | lking | Electrical Inspections | 8 | 5/2/10 6:40 PM |
| PLEASE HELP! Need to change the SOPs, per NEMA | ktarasenko | Electrical Inspections | 76 | 4/19/10 8:15 PM |
| Type of fasteners in service panel | bhartley | Electrical Inspections | 3 | 2/10/09 8:45 PM |
| Avoiding Litigation Thread. | gromicko | Miscellaneous Discussion for Inspectors | 147 | 5/8/06 6:41 PM |
| Patio Roof Flashing | tneumann | Exterior Inspections | 16 | 3/24/06 8:47 AM |
