Securing your ladder while you're on the roof. Best method?
There are so many different conditions, some you can use a bungee, some there’s no place to hook it. What’s the best method for a wide variety of conditions?
What I have is a 36" bungee, with a 1" spring clamp on each end of bungee. I drilled a hole in the clamps and then bent the metal hooks down so that the clamps will not come loose. I’m able to clip onto the drip edge without damage.
I just wear my Jesus shoes:p
you could get your assistant to hold it…or not :|.)
It depends on the vehicle you use.
I found a good one here http://www.true-racks.us/
Reread the title of the post;)
Oops :shock:
I use bungee or have assistant hold ladder while I’m roof. One of the benefits of the team approach.
You guys don’t use Cherry Pickers ?
