Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 1/11/11, 11:57 PM
James R. Szczesny's Avatar
James R. Szczesny James R. Szczesny is offline
Default Shingled valley
Is it possible to tell if the valley is properly shingled. No leaking is noticed underneath.
J.Szczesny
4 Seasons Home Inspections
Washington State Inspector # 711
800 5th Ave #101-385
Seattle, Wa 98104
(206)391-0285
online @ www.4seasonsinspects.com
email @ info@4seasonsinspects.com
toll free cal @ 866-512-9972
"For the best protection,
get the right inspection"
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/12/11, 1:17 AM
Jeffrey R. Jonas's Avatar
Default Re: Shingled valley
Got a pic of the entire roof from ground level? All those angles are giving me an 'optical contusion'!
Old 1/12/11, 2:57 AM
Bob Elliott's Avatar
That sharp angle makes it look like water could come in from the sides but I am surprised one of the roofers has not responded yet.
I see nothing about angle limitations however go to 2:22 of this GAF video to see how they overlap to help you think about it.
Nailing,corner cut and sealant are important.
Old 1/12/11, 3:18 AM
Stephen W. Stanczyk's Avatar
Any type of butterfly roof gives me the willys especially in the weather we have up here. I can only remember seeing two in the last 6 years. One was rotted through and through, the other was cut similar to yours. Didn't find any issues in the valley but the roof was getting near replacement so I recommended a further evaluation with special attention paid to the valley and the chimney.
Stephen Stanczyk
Old 1/12/11, 8:15 AM
Sean Fogarty's Avatar
It is just a cut valley. If you can get a shingle up the bottom layer should extend a good 6 inches onto the other side and then the cut shingle goes over it. If its not leaking then it should be fine.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 1/12/11, 8:19 AM
Peter C. Russell's Avatar
I agree. Although the cuts don't appear to line up, sloppy work, it should be OK.
Doubt the shingle MFG. would warranty it but they never do anyway.
Russell Inspection Services
New Hampshire state license # 57
Level I Thermographer, ITC
Certified Building Science Thermographer, ITC
Certified Building Analyst, BPI
Certified Commercial Inspector, ITA
Certified Septic Evaluator, GSDI #148
www.newenglandthermalimaging.com
www.russellinspectionservices.com
www.nhsepticinspection.com
Old 1/12/11, 9:01 AM
David C. Macy's Avatar
Why does the moss only appear on one side of the valley.
I would not have a problem with the cut valley.
The moss I have a problem with.
Old 1/12/11, 11:27 AM
Awesome guys,,,thx for all the input, I didn't see any issues but noted it wasn't the best detail for this paticular valley.
J.Szczesny
Seattle, Wa 98104
(206)391-0285
Old 1/13/11, 12:34 AM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
Are you sure that valley is not being used as a grow-opp?
The valley's OK but debris is collecting due to several factors.
1: I bet they ( roofers ) did not cut the top of the shingles top upper section that is angled, that is closest to the valley at a 45 % angle to stop rain water from coming back on the shingle ridge.
2: the could have opened the valley to allow faster runoff and repel snow and ice.
3: it looks like a 5/12 so at the valley it will be less of an angle so that is even more reason to cut it open.
4: Tress,s are leaving it shaded so moss and other organic materials will take hold easier.
A simple maintenance will stop the effect form gathering speed to destroy the roof.
Just my opinion.
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Old 1/13/11, 12:42 AM
Just my opinion.
I think you are right, Robert.
It is pretty typical here in Seattle to have moss on the roof.
This type of valley is typical in dryer climates and works best in a valley with 2 different pitches.
I see it as problematic but there is no issues currently.
Seller is aware. It is a pre-listing inspection.
J.Szczesny
Seattle, Wa 98104
(206)391-0285
Old 1/13/11, 3:08 PM
All you confirm is what you can see. That looks like a very typical cut valley. The cut shingles should have stopped short of the valley center-line a couple of inches, but cutting along the center-line is a very common mistake and I wouldn't mention it if I saw no sign of leakage in a roof that had been in place for a while. I might mention it on a new home but I'd also mention that it almost never causes leaks.
The moss on one slope probably has to do with shading. The only way to distinguish between cut valleys and California cut valleys is to look at the base of the valley for the bottom of the starter strip.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 1/13/11, 3:15 PM
Good tip, Kenton.
Old 1/13/11, 7:59 PM
I have never seem valleys finished like that Ken.
Its appears to be woven at the end.
It must be inbreed-ed ( shingles ) in plastic to prevent water tracking under that style of valley.
Would never cut it in Quebec and roofer would be fined of hear from RBQ.
Old 1/14/11, 2:01 AM
Pretty common in CA and CO, Robert. I can't speak for other places. I've never personally found a valley I could blame on this type of installation, but when you factor in shingle quality, installation quality, roof design, homesite, etc. there are probably places where they're sorry they didn't pay a little more and get a better job.
(303) 717-8940
Old 1/14/11, 6:37 AM
Love to see some photos of the process Ken. Sorry for the edit all, but when I looked close at the install it looks like the woven part is lifting due to shrinkage and water has traced underneath, henceforth the under layment and decking, fascia board are rotting also.
Is it the photo or is the valley off center cut. I see no metal valley and the cut to the weaving takes place on the upper plane by several inches. am I mistaken?
I did straight woven valley 25 years back. No cutting just weave.
Again love to see photos Ken.
Thanks...Robert
Valley dmacy Exterior Inspections 35 3/31/09 8:56 AM
Porter Valley Software (InspectVue) has been sold. gromicko Inspection Hardware, Software & Publications 28 8/8/08 10:43 PM
NY NACHI Hudson Valley Chapter Meeting pmaietta General Inspection Discussion 0 4/10/06 7:03 PM
NY NACHI Hudson Valley Chapter Meeting pmaietta General Inspection Discussion 3 3/3/06 10:43 AM
NY NACHI Hudson Valley Chapter Meeting pmaietta Miscellaneous Discussion for Inspectors 0 2/27/06 1:42 PM
