Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 11/4/09, 9:17 AM
David C. Macy's Avatar
Default Stains at vents/roof
Stains around roof top vents.
The roof was one layer standard 3 tab shingle about 10 years old. Gable/moderate slope.
House had soffit/gable/roof top venting. Insulation was loose fill about 6-9 inches. No moisture stains in attic, ventilation seemed to be adequate.
So what is causing the stains around the vents?
How would you report the scenario?
Would an active vent like a power vent be an solution? Or maybe adding more soffit vents. (There were no baffles installed but the insulation was not blocking the vents.
Thanks for the time.
Find an InterNACHI certified Iowa Home Inspector (and anywhere else in North America)
Old 11/6/09, 6:00 PM
Default Re: Stains at vents/roof
Did the rooftops of neighboring homes have the same problem?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/6/09, 6:04 PM
I did not look at any other roofs.
Old 11/6/09, 7:54 PM
I don't know. It looks like some kind of airborne particulates coming out of the attic plated out on the shingles. The source of the particulates?
  • What's the fuel for the heating system?
  • Did any exhaust flues terminate in the attic, including bathroom vents?
  • Was there a whole-house fan?
  • Was there any discoloration of wall or ceiling surfaces in the living space or of framing or sheathing in the attic?
  • If moist air was evacuated through the roof vents, it could be algae, although if those roof vents were galvanized and that was algae, there would be clear streaks on the downhill side from runoff, since algae doesn't like zinc.
(303) 717-8940
Old 11/6/09, 8:06 PM
mvaage mvaage is offline
Do they have a wood fireplace?
Old 11/6/09, 8:29 PM
William Warner's Avatar
William Warner William Warner is offline
Looks like over spray pattern to me (like spray paint or some chemical put on the vents). Certainly is interesting what ever it is.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 11/6/09, 9:37 PM
Brian E. Kelly's Avatar
Good question Kenton. Looks like an unexplained anomoly to me. If there was no dicernable damage I might not call it out, or you might recommend to monitor it.
Either way great pic and interesting
Old 11/6/09, 9:41 PM
Natural Gas
Possably one bath vent. Termination not visible but may of discharged at a soffit. (Covered with insulation)
No
No
No stains at plumbing stack.
Old 11/6/09, 9:42 PM
Yes the home did have a wood burning fireplace. It was at a lower level slab.
Old 11/6/09, 9:47 PM
Bob Elliott's Avatar
Got any attic pics?
This was a Condo building roof ,so I never got to the attic or roof due to no access.
22 footer not enough, but I did notice the stains.
Old 11/6/09, 9:52 PM
Originally Posted by belliott View Post
Got any attic pics?
No, there were no visible issues. In the upper attic. Insulation, roof structure and even the ventilation seemed fine.
The lower attic had some indications of past leaking from an upper rrof downspout discharging onto the lower roof surface. (They recently extended)
Old 11/6/09, 9:56 PM
Your picture looks like a one time event the way it is all so even .
Old 11/6/09, 10:12 PM
They were not shadows as it was cloudy. Maybe I was in the twilight zone!!
Old 11/7/09, 7:28 PM
Is there a possible leak in the attic from the fire place?
Old 11/7/09, 7:51 PM
James F. McKee's Avatar
sure looks like smoke damage David but You are not saying anything that would indicate that as a possibility....maybe it was martians...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
ceiling stains wsiegel Interior Inspections 9 12/7/09 10:39 AM
Interior stains rbusch Structural Inspections 3 10/6/09 3:45 PM
Stains on masonry blocks. dmacy Structural Inspections 3 5/9/09 4:25 PM
Help with stains on interior wall/ceiling rborders Interior Inspections 2 12/21/07 11:58 PM
Stains on brick beside chimney jfunderburk Structural Inspections 24 11/29/07 9:02 AM
