Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Roofing Inspections
Old 3/15/11, 12:11 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default Step flashing on roof overlay
What do you report if there is no step flashing installed on a rake wall when it is a second layer of roof shingles?
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/15/11, 12:13 PM
Roy D. Cooke, Sr's Avatar
Default Re: Step flashing on roof overlay
If I can not see it I write it up as Suspect no flashing on Roof wall . Further evaluation by qualified person .
Old 3/15/11, 12:28 PM
Jeffrey R. Jonas's Avatar
Are two layers of shingles allowed in your area? It is not in many. Also as Roy stated, if I (you) can't see it, report it. Also, I would call out the shingles against the wood siding anyhow.
Joe Funderburk, CMI's Avatar
Are you sure it isn't behind the siding? Did you raise the shingles at the gutter?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/15/11, 12:51 PM
Bob Elliott's Avatar
No kickout .
Old 3/15/11, 1:23 PM
There is definitely no step flashing at this covering. So I'm writing it up as no step flashing. However, what if there is step flashing installed at the first layer? Would this not be good, and is this what the installer was thinking so as not to remove the siding?
Oh, and good catch Bob with the missing kick out flashing.
774 Manor Road
718-514-3393
Old 3/15/11, 1:26 PM
Two layers are allowed here. Up to about a year ago, you could have installed 3 layers, believe it or not.
774 Manor Road
718-514-3393
Old 3/15/11, 1:32 PM
James E. Braun, CMI's Avatar
In my area, if there is flashing at the first layer, none is installed at the second layer.
Old 3/15/11, 1:33 PM
I believe it. It was allowed here for a long time also.
I can't see why it would be necessary.
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/15/11, 1:35 PM
Do they trim the shingles back away from the siding?
Old 3/15/11, 2:20 PM
Christopher Currins's Avatar
Yes. By condition of shakes, and if no visible damage inside, I'll bet there is flashing installed with 1st layer. So there is no need to remove it and replace when 2nd layer was installed.
You should be able to see metal flashing at siding/shingle joint.
Christopher Currins
Certified, Licensed
Old 3/15/11, 2:43 PM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
If the siding is in contact with the shingles, it will also wick moisture causing damage, rot. I recommend siding be cut back so as to provide a gap. Like here
Old 3/15/11, 3:07 PM
Very nice thanks Linas
Old 3/15/11, 3:19 PM
David C. Macy's Avatar
I believe I obtained this verbiage from Marcel.
The roof to wall step flashing cannot be verified for proper installation nor its existence due to the wall siding having been installed tight on to the shingle surface.
It is a standard of practice to leave the siding up from the shingle surface 2” to a min. of 1”. This is needed to prevent water on the roof from being wicked up into the siding material.
If vinyl sided add ...Since wicking is not a problem with vinyl siding, the gap should still exist to allow future removal or replacement of the shingle roof surface. It also allows to see the step flashing and monitor any damage to it, should any leakage occur in that roof to wall juncture.
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 12:52 PM
Looking for a comprehensive source on residential roof flashing kshepard Exterior Inspections 9 1/18/09 11:57 PM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 12:21 AM
Step flashing at vertical wall? jlybolt Exterior Inspections 31 2/12/06 11:40 AM
Moss growing on roof ecox1 Exterior Inspections 45 1/19/06 9:57 PM
