Home Inspector Forum Archive
These message board pages are now for archival purposes only. Please visit https://www.nachi.org/forum/ for our most recent forum discussions.
shower hot water
AuthorMessage
robin
NACHI Member: No
(as of 3/25/07)
Inactive Poster
Posted: Jan 29, 2005 1:16 PM       Post Subject:
Please Note: This user is a non-member guest and is in no way affiliated with NACHI.
I am new, so please excuse if this question is elementary.
I can no longer get consistent hot water out of my shower. The best I can hope for is lukewarm. My place is 1 year old and I can hot water other places, sink, etc. I removed the shower faucet to look for problems, i.e. mixing valve, but my search has not yielded any possible solutions to this problem.
I would appreciate any help to this matter,
Thank you in advance,
Robin bell
Back to Top
Paul Hinsperger
Hinsperger Inspection Services Ltd
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: phinsperger
Posted: Jan 29, 2005 2:15 PM       Post Subject:
Robin,
1) Is there one handle that controls both the hot and cold or is there a separate handle for each?
2) If you turn only the hot water as open as you can, how does the flow compare to if you turn only the cold as open as you can?
Paul Hinsperger
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Back to Top
Larry Franklin
HomeTeam Inspection Service
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: lfranklin
Posted: Jan 29, 2005 3:12 PM       Post Subject:
Another icon_question.gif Robin
Do you have hot water at first then goes to luke warm or just warm all the time?
Did you ever have hot water at this location?
Back to Top
dspencer
NACHI Member: No
(as of 3/25/07)
Active Poster
Posted: Jan 29, 2005 6:50 PM       Post Subject:
Hot water on sinks working fine? Most likely the valve is a scald proof valve and needs the dial set back....usally builders make the master bedroom hotter that hallways due to kids use the hall bath....
What brand Model is the valve?
Back to Top
robin
NACHI Member: No
(as of 3/25/07)
Inactive Poster
Posted: Jan 29, 2005 7:58 PM       Post Subject:
Paul: It is only one handle for hot and cold.
Larry: It is mostly warm all the time, and occasionaly it will become enjoyably hot, and thanks for the welcome note.
Darren:
I am not sure which model ithe valve is, but there isn't anything at all on it that is adjustable, that I see.
Thanks for the replies thus far.
Robin
Back to Top
Paul Hinsperger
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: phinsperger
Posted: Jan 30, 2005 8:19 AM       Post Subject:
Robin,
Most likely the problem is with the faucet mechanisim. The inner valve may have gotten plugged or possiblly turned a few degrees out of normal. That is the first place I would start.
Paul Hinsperger
here !
Back to Top
robin
NACHI Member: No
(as of 3/25/07)
Inactive Poster
Posted: Jan 30, 2005 9:12 AM       Post Subject:
Paul:
How would I check this inner valve? When I looked at it before( I believe), there did not appear to be any way to adjust it. icon_redface.gif
Thanks again,
Robin
Back to Top
Paul Hinsperger
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: phinsperger
Posted: Jan 30, 2005 2:36 PM       Post Subject:
Robin,
Of course not all faucets are the same but the basic principle is the same Below is an example of an older MOEN faucet.
1) Turn off the water
2) Open the valve both to hot and cold to releive any water preasure
3) Plug the drian so that any small parts won't be lost down the drain
4) Pop off the cap
5) Remove the retaining screw and handle
6) Remove the cartridge retaining clip
7) Pull out the cartridge. Be sure not to damage any O-rings and note the orientation of the cartigde. For the most part groves, notches, tabs, etc should either be perfectly vertical or horizontal. If they are not this might be causing the problem your having.
8 ) Examine the cartrigde and clear out any gunk that might be clogging the passageways.
9) To assemble the faucet just reverse the steps you did to remove it.
Paul Hinsperger
here !
Back to Top
JERALD (JERRY) STEWART
STEWART PROPERTY INSPECTIONS INC.
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: jstewart1
Posted: Jan 30, 2005 2:50 PM       Post Subject:
WOW,
Back to Top
Adam Slimack
A Plus Home Inspection
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: aslimack
Posted: Jan 30, 2005 3:15 PM       Post Subject:
Paul, Could you be a little more specific?
Adam, A Plus
Back to Top
cmccann
NACHI Member: No
(as of 3/25/07)
Very Active Poster
Posted: Jan 30, 2005 3:49 PM       Post Subject:
Paul, Is that your shower, or did you do this at an inspection?
NACHI MAB!
Back to Top
Paul Hinsperger
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: phinsperger
Posted: Jan 30, 2005 4:28 PM       Post Subject:
That's my shower. I think I should have cleaned it before taking the pictures. icon_redface.gif
Paul Hinsperger
here !
Back to Top
jbehling
NACHI Member: No
(as of 3/25/07)
Very Active Poster
Posted: Jan 30, 2005 6:31 PM       Post Subject:
Back to Top
William Warner
BC Warner Home Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: wwarner
Posted: Feb 1, 2005 11:06 PM       Post Subject:
Good show Paul!
That's better than any "tech" service could do!
Bill
It's only Rock 'n Roll.... but I like it!
Back to Top
Aaron
NACHI Member: No
(as of 3/25/07)
Inactive Poster
Posted: Feb 2, 2005 8:18 PM       Post Subject:
EDIT
Back to Top
David Valley
Certified Massachusetts Home Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: dvalley
Posted: Feb 2, 2005 10:07 PM       Post Subject:
Good Job Paul.
Now that you have that apart, show everyone what to do in order to stop a drip at the spout on that particular handle.
David Valley
MAB Member
Massachusetts Certified Home Inspections
http://www.masscertified.com
"Some cause happiness wherever they go; others, whenever they go."
Back to Top
