Fuse panel on outside of house!!!
These message board pages are now for archival purposes only. Please visit https://www.nachi.org/forum/ for our most recent forum discussions.
AuthorMessage
Doug Edwards
Acorn Home Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: dedwards
Posted: Jun 17, 2005 6:07 PM       Post Subject:
Has anyone ever run across a fuse panel on the outside wall of the house exposed to the weather, etc. Imagine changing a fuse during a storm while standing on wet soil. See photos.
[ Image: https://www.nachi.org/bbsystem/usrimages/n/not_weather_rated_.jpg ]
[ Image: https://www.nachi.org/bbsystem/usrimages/o/old_fuse_panel_outside.jpg ]
[ Image: https://www.nachi.org/bbsystem/usrimages/o/open_knockouts.jpg ]
Back to Top
Doug Edwards
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: dedwards
Posted: Jun 17, 2005 6:12 PM       Post Subject:
Oh yeah, I forgot to mention it was at about 4 foot level, just about kiddie height. The panel above it is the Main with a loose dead cover w/o any screws holding it on. It got worse.
Back to Top
bbadger
NACHI Member: No
(as of 3/25/07)
Very Active Poster
Posted: Jun 17, 2005 6:13 PM       Post Subject:
Please Note: This user is a non-member guest and is in no way affiliated with NACHI.
Those are NEMA 3R panels (Raintight Panels) they are made to be outside.
That said very few if any dwelling units in this area have outdoor panels, most are in the basements. icon_cool.gif
I do not enjoy working on any outdoor electrical equipment in the rain or snow. icon_sad.gif
Bob Badger
Electrical Construction & Maintenance
Moderator at ECN
Back to Top
Robert OConnor
Eagle Engineering & Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: roconnor
Posted: Jun 17, 2005 6:16 PM       Post Subject:
Looks like the right exterior enclosure type (NEMA 3R) since the cover swings up. Did it appear watertight, with no signs of significant corrosion?
There are also other issues with fused panels, like making sure Type-S (rejection base) fuses have been installed and that local homeowner insurance companies are okay with fused panels. Although my opinion is that fused panels are actually safer ... but lets not go there again ... icon_lol.gif
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Back to Top
Doug Edwards
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: dedwards
Posted: Jun 17, 2005 7:14 PM       Post Subject:
Not particularly rusted inside but some surface rusting and lots of critter droppings inside and a few lizard skeletons. They probably threw themselves onto the bus to end the misery of living here. Cover did not close tightly so I doubt it is very water tight. Home is a 1948 circa. Lots of hair raising electrical discrepancies in the attic, crawl space and outbuilding.
Back to Top
bbadger
NACHI Member: No
(as of 3/25/07)
Very Active Poster
Posted: Jun 17, 2005 7:29 PM       Post Subject:
Not trying to bust your chops here just passing on some info.
To the NEC raintight is not at all the same as watertight.
3R equipment can really only handle rain or water coming down from above. They also have drain holes on the bottom to let out the water that will leak in.
Not the sort of equipment to be used in car washes or commercial kitchens where water may be sprayed horizontally.
Water and oil tight equipment are classified 4 or 4x minimum. Equipment with those ratings have gasketed covers and no drain holes.
Bob Badger
Moderator at ECN
Back to Top
Doug Edwards
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: dedwards
Posted: Jun 17, 2005 7:39 PM       Post Subject:
Bob,
Thanks, that is good information to have. I don't get offended when someone is trying to pass on info. A lot of years in military. Anyone want to chew on my butt all they are going to get is scar tissue. I appreciate your help.
Back to Top
Larry Kage
Welcome Home Inspection Services, LLC
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: lkage
Posted: Jun 17, 2005 8:38 PM       Post Subject:
"I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
Back to Top
Robert OConnor
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: roconnor
Posted: Jun 18, 2005 12:23 AM       Post Subject:
Bob is correct ... the exterior panel should be "weathertight" (not watertight") ... that is what I really meant ... icon_wink.gif
Robert O'Connor, PE
Eagle Engineering ?
Back to Top
bbadger
NACHI Member: No
(as of 3/25/07)
Very Active Poster
Posted: Jun 18, 2005 5:45 AM       Post Subject:
dedwards wrote:
Bob,
No problem and I am glad you took as helpful and not nitpicking. icon_smile.gif
I agree with Larry, that is a good one.
Bob Badger
Moderator at ECN
Back to Top
jtedesco
NACHI Member: No
(as of 3/25/07)
Very Active Poster
Posted: Jun 18, 2005 2:27 PM       Post Subject:
If those Edison base fuses are 30 amperes they are supposed to be replaced with an adapter and properly sized Fustats because there is evidence of over fusing.
Joe Tedesco, NEC Consultant
www.nachi.org/tedescobook.htm
Back to Top
Robert OConnor
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: roconnor
Posted: Jun 18, 2005 3:55 PM       Post Subject:
That is the NEC requirement (240.51), but I tend to take a little more conservative apparoach wearing my HI hat and recommend that ALL edison base fuses be replaced with the Type-S rejection base inserts and fuses.
TYPICAL TYPE-S INSERTS & FUSES:
There was also a pretty good discussion on fused panels a while back ... CLICK HERE
Robert O'Connor, PE
Eagle Engineering ?
Back to Top
