Technical Links Page - Plumbing
These message board pages are now for archival purposes only. Please visit https://www.nachi.org/forum/ for our most recent forum discussions.
AuthorMessage
Claude Lawrenson
Ontario Home Inspections Inc.
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: clawrenson
Posted: Jun 27, 2005 1:15 PM       Post Subject:
Ditto Robert's post:
Quote:
This is kind of like a start of a NACHI Technical Links page, that I think the Education Committee should eventually develop.
Right now online education is the priority, but I would like to develop a Technical Links and Research section as a long range plan. Organized by major topic/system, and then possibly sub-systems. Then if someone has a question they can research that topic with the technical links ... or it could be linked to answer a question on the BB.
Just an idea ... and could members please post any good technical links related to this first "beta" links listing by posting it here (and I will keep updating the topic for additional good links) ...
Regards, Claude
Plumbing System Education Resources (Work In Progress)
Books
Basic Plumbing - http://www.acontractorslicense.com/books/bpir-chapter.html
Code Check Plumbing - http://www.amazon.com/exec/obidos/ASIN/1561586242/ref=pd_sxp_elt_l1/002-7240962-2068068
National Plumbing Codes Handbook - http://www.maintenanceresources.com/bookstore/pipingplumbing/natplumbingcodes.htm
(Plumbing) Books - http://www.bookmarki.com/browseproducts/Plumbing-and-Piping-Systems-Inspection-Notes--Up-to-Code.html
Care & Repair
Bath/Kitchen Rehab Guide - http://www.pathnet.org/sp.asp?id=1009
Common Plumbing Repairs - http://www.gogeisel.com/geiselonline/plumbing/Common_Plumbing_Repairs.html
(The) Plumber.com - http://www.theplumber.com/handbook.html
Plumbing Projects - http://www.hammerzone.com/archives/plumbing/index.htm
Plumbing Rehab Guide - http://www.pathnet.org/sp.asp?id=998
Renovating Your Bathroom - http://www.cmhc-schl.gc.ca/en/burema/gesein/abhose/abhose_ce36.cfm
Renovating Your Kitchen - http://www.cmhc-schl.gc.ca/en/burema/gesein/abhose/abhose_ce35.cfm
Code
Code (Plumbing) - http://www.iapmo.org/
Section 9.02.07 International Plumbing Code - http://ci.huntsville.tx.us/hr/ordinances/Title_9/02/07.html
Drainage & Sewage
Q & A - http://doityourself.com/drainage/index.shtml
General Info
Air Admittance Valves - http://www.toolbase.org/tertiaryT.asp?TrackID=&CategoryID=1315&DocumentID=2127
Backflow - http://abpa.org/introduction.htm
Backflow Prevention - http://www.keidel.com/mech/backflow-h20.htm
Bacteria Fact Sheet - http://www.extension.umn.edu/water/bacteria.html
Cisterns - http://edis.ifas.ufl.edu/scripts/htmlgen.exe?DOCUMENT_AE029
Dielectric Union - http://www.hammerzone.com/archives/plumbing/systems/components/union_de/intro.htm
General Info (PL101) - http://www.friendlyplumber.com/plumbing101.html
Gray water - http://homeenergy.org/archive/hem.dis.anl.gov/eehem/95/950712.html
History of Plumbing - http://www.theplumber.com/H_index.html
Home Water Treatment - http://www.homewatertreatment.com/EPAstandards.htm
Hot Water Circulating Systems - http://www.chilipepperapp.com/hwcs.htm
Household Plumbing An Overview - http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/HousePlumb.html&rn=RightNavFiles/rightNavHowTo
Lead Fact Sheet - http://www.extension.umn.edu/water/lead.html
Materials - http://www.mymotherlode.com/Home_Improvement/hi_article_plumbing.html
Noises (Plumbing) - http://www.mub-albertville.com/Noises_in_the_Plumbing_System.htm
Percolation Tests - http://septic.umn.edu/Professional/RunAPercolationTest.htm
Plg.com ? General Info - http://www.plbg.com/
Plumbing Basics - http://www.easy2.com/cm/easy/diy_ht_index.asp?page_id=35694452
Plumbing Diagram - http://houseandhome.msn.com/improve/plumbing.aspx
Plumbing Industry Links - http://www.pmihome.org/links.shtml#2
Plumbing Maintenance - http://www.friendlyplumber.com/plumbing101/how_tos/plumbing_maintenance2.html
Tankless Water Heaters - http://www.toolbase.org/tertiaryT.asp?TrackID=&CategoryID=1436&DocumentID=2138
Technical Info - http://www.toolbase.org/secondaryT.asp?TrackID=&CategoryID=1289
Toiletology - http://www.toiletology.com/index.shtml
Toilets - Howstuffworks - http://home.howstuffworks.com/toilet.htm
Ultraviolet Purifiers - http://www.wisegeek.com/what-are-ultraviolet-purifiers.htm
Water Quality Fact Sheets - http://www.extension.umn.edu/water/drinking_water.html
Water Heaters - http://homeenergy.org/archive/hem.dis.anl.gov/eehem/96/960510.html
Water Heaters (On-demand) - http://www.wisegeek.com/what-is-an-on-demand-water-heater.htm
Water Heaters (Tankless) - http://www.wisegeek.com/what-is-a-tankless-water-heater.htm
Water Heaters (Tankless) - http://www.water-professor.com/
Water Heaters (Most Efficient)- http://www.wisegeek.com/what-is-the-most-efficient-type-of-water-heater.htm
Water Softeners - http://www.bizlux.com/how_does_water_softener_work.htm
Water Wells - http://www.wellowner.org/awellmaintenance/annualcheckup.shtml
Water Tech Briefs - http://www.nesc.wvu.edu/ndwc/ndwc_tb_available.htm
Piping
Advantages of Copper - http://www.wisegeek.com/what-are-the-advantages-of-copper-plumbing.htm
Copper Piping - http://64.90.169.191/copperhome/PHC/phc_home.html
IPEX Piping - http://www.ipexinc.com/Content/EN_CA/2_0_Products/2_4_Plumbing_Mechanical/2_4_7_PlumbBetter.asp
PEX Piping - http://www.vanguardpipe.com/vanex.html
PEX Piping - http://www.rehau-na.com/rehau.construction/heating.and.plumbing/pex.plumbing/why.choose.pex.plumbing..html
Pipe Size - http://www.terrylove.com/watersize.htm
Piping (Types) - http://www.terrylove.com/pipe.htm
Plumbing Equipment
American Standard - http://www.americanstandard.com/
Amtrol - http://www.amtrol.com/valve.htm
A.O. Smith - http://www.hotwater.com/
Bradford White - http://www.bradfordwhite.com/
Burnham - http://www.burnham.com/
Plumbing Manufacturer?s Institute - http://www.pmihome.org/techedu-articles-2001-may.shtml
Rehau - http://www.rehau-na.com/rehau.construction/heating.and.plumbing/program.overview.html
Rheem - http://www.rheem.com/
Zurn - http://www.zurn.com/operations/pexrh/pages/qest_typical.asp
Plumbing ? General System Info
Fluid Mechanics - http://physics.about.com/cs/fluiddynamics/a/160903.htm
Plumbing Systems1 - http://www.chilipepperapp.com/ps.htm
Plumbing Systems2 - http://www.uvi.edu/Physics/SCI3xxWeb/Plumbing/Plumbing.html
Plumbing Systems3 - http://web1.msue.msu.edu/msue/imp/mod02/01500600.html
Plumbing Systems4 - http://web1.msue.msu.edu/msue/iac/disasterresp/HomeImprovement/2094.pdf
Plumbing Systems5 - http://www.msdlouky.org/programs/whenuflush/index.htm
Plumbing Test
Merit Badge - http://www.meritbadge.com/files/mb-pdfs/Plumbing.pdf
Homeowner?s Guide - http://www.dora.state.co.us/plumbing/forms/ho_info.pdf
Septic Systems
NSFC Septic News - http://www.nesc.svu.edu/nsfc_septicnews.htm
Septic System Information Website - http://www.inspect-ny.com/sepbook.htm#mainwebs
Septic Systems - What you need to know - http://www.bae.ncsu.edu/programs/extension/publicat/wqwm/wm1.html
Back to Top
Greg Bell
Bell Inspection Service
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: gbell
Posted: Jun 27, 2005 3:56 PM       Post Subject:
Great work Claude!!!
You are a great asset for all NACHI members.
Greg Bell
Back to Top
rmoore
NACHI Member: No
(as of 3/25/07)
Very Active Poster
Posted: Jun 27, 2005 4:12 PM       Post Subject:
Please Note: This user is a non-member guest and is in no way affiliated with NACHI.
Good stuff Claude.
Just one thing after a very quick scan. You might add a direct link to Bradford-White serial numbers as it's probably the one that gives most trouble. The link is at http://rightspec.bradfordwhite.com/Other/Serial%20Number%20Identification.pdf . You can get there from the main site but it takes a LOT of digging.
Do you know if these lists are going to be "sticky" at the top of the sections or somewhere else?
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Back to Top
Claude Lawrenson
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: clawrenson
Posted: Jun 27, 2005 4:20 PM       Post Subject:
That is a great suggestion. It certainly has a lot of value if it was assigned to each of the discussion topics. Hopefully it can be a long term, extensive resource.
Thanks for the suggestions.
Back to Top
Robert OConnor
Eagle Engineering & Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: roconnor
Posted: Jun 27, 2005 8:22 PM       Post Subject:
I have a bunch of links I could probably add when I get the time to go through them. But here is one attitional one to put under a possible sub-topic of "Homeowner Plumbing Repairs"
Temporary Plumbing Repair Material ... http://www.gale-edit.com/products/volumes/duct_tape.htm
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Back to Top
tallen
NACHI Member: No
(as of 3/25/07)
Very Active Poster
Posted: Jun 28, 2005 1:54 AM       Post Subject:
This is great info!
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Back to Top
Joseph Kormos
A-1st Look Home Inspectors Inc.
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: jkormos
Posted: Jun 28, 2005 9:06 AM       Post Subject:
Yes thanks for taking the time out to put the listing together icon_biggrin.gif
Back to Top
Robert Brown
A.C.I.S.S. Home Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: rbrown1
Posted: Jul 12, 2005 11:03 PM       Post Subject:
This is great stuff Claude!
Sorry for the late post but I have been away. However my posting does "bump" it up eh! icon_lol.gif
Would you have any objections if I uploaded any of these links to my websites?
Thanks to all who posted these links..............very informative!
Bob Brown
President NACHI Du-Ka Chapter ON. Canada
NACHI Cell: 1-484-429-5465
ACISS Home Inspections
bob@aciss.biz
Certified Adult Training Services
www.certifiedadulttrainingservices.com
info@certifiedadulttrainingservices.com
Back to Top
Rick Harrington
Patch Independent Home Inspections, LLC.
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: rharrington
Posted: Jul 13, 2005 8:28 AM       Post Subject:
Today is a great day for all NACHI inspectors !!!!!!
YOU GUYS ARE PROVIDING A LOT OF INFO.
Thanks,
Rick
Rick A. Harrington
Central Ohio Home Inspections
www.patchhomeinspections.com
Back to Top
jmurphy1
NACHI Member: No
(as of 3/25/07)
Active Poster
Posted: Jul 13, 2005 8:32 AM       Post Subject:
thank you claude and others
Back to Top
Brian Kelly
Dwelling Doctors LLC
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: bkelly2
Posted: Nov 29, 2005 11:51 PM       Post Subject:
Back to Top
