Maybe this is why the Crawlspace is wet!
Originally Posted By: mgault
http://www.nachi.org/bbsystem/usrimages/0/050810033634.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/0/050810032954.JPG ]
I recommended...
opening the blocked vents (did it while I was in there),
fixing the dryer vent to the exterior,
remove all the wet insulation,
mechanically ventilate the crawlspace with fans from the garage and install a proper vapor retarder,
reinstall dry installation...
Moisture was mostly condensate from the HVAC ducts. All the damaged batts were within 3 or 4 feet of the ducts...
Whew! One more reason why I hate crawlspaces!
-Mike
A to Z Home Inspections, LLC
www.atozhomeinspections.net
Originally Posted By: Jay Moge
the white tube looks like a dryer vent and should be run outside threw the “blocked vent” which may once have been a celar window. (had 2 or 3) usualy the grade creeps up to the window and pop… replace with whatever you have. simple $10 fix. new vent hose and penetrating vent with cap.
active and that dryer air under there should remediate sufficiently to preclude further treatment…
He's very happy to have obtained a second opinion ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif) . Sale will close on time.
-Mike
