What is this?
Originally Posted By: charper
http://www.nachi.org/bbsystem/usrimages/x/xxx_Small.jpg ]
Charlie
www.HomeInspectionGa.com
Originally Posted By: dedwards
Vinyl sheet goods have a paper backing that is gray in color. If moisture or more importantly, water gets under the vinyl, the paper backing darkens. It can happen a number of ways; poor seal around the base of toilet, wear and tear on the surface, just being constantly wet can eventually cause it to happen. I have never heard of any way to reverse it as it is not cost effective. Typically most folks just replace it. It has a tendancy to just get worse once it begins.
Originally Posted By: gporter
This is very common when people miss the toilet in the dark
Gary Porter
GLP’s Home and Mold Inspections LLC
Orlando, Fl 32828
321-239-0621
www.homeandmoldinspections.com
Originally Posted By: Jay Moge
looks like a fairly new toilet? i’d guess tank sweat and like Doug said, water damage to vinal floor backing. i see it all the time. they need a new piece of vinal. icon_cool.gif
Originally Posted By: Monte Lunde
Here are some causes,
Wax bowl is not set
Toilet is loose
No caulking around the bowl (Caulking will help so water can not get under the vinyl).
Monte Lunde CCI, CCPM, CRI
Viking Construction Services Inc.
Originally Posted By: ckratzer
Charles,
Simple.Toilet is leaking.That area usually indicates wax ring did not seat.Recommend that a plumber is needed to make required repairs.Recommend vinyl to be replaced as mold has begun to grow between vinyl ply and its paper backing.
Good day
Cheremie
Originally Posted By: dnice
ckratzer wrote:
Charles,
Good day
Cheremie
First take a look at the subfloor (if possible) from underneath to see if it has penetrated. Then I would first recommend consulting the owner as to whether there had been any recent plumbing repairs and if so, to produce receipts.
I would only recommend that a qualified plumbing professional be consulted. Let him/her make the call as to the specific needed repairs, if any.
Originally Posted By: mcyr
Sounds like a Dunkin-Donut to me. ha. ha.
Marcel
