moisture meters
Originally Posted By: jclark1
Hi. Any advice on moisture meters? Should I spend extra money on the better models, features? Do I need to get a meter with non-invasive measuring in addition to the standard pin test probes? I’m looking at the Protometer mini. Any advice out there?
Thanks,
James
Originally Posted By: troberts1
I like the GE Proamitor Serveymaster it is both Invasive and non invasive in one meter. icon_wink.gif
Originally Posted By: rhinck
James,
I like Ted use the GE model and am very satisfied.
Rick
Originally Posted By: whandley
Tramex Moisture Encounter Plus!
"I travel the globe to protect my clients!"
Progressive Inspection Service
California Home Inspectors
Orange County Home Inspectors
www.progressiveinspection.com
(949) 499-8054 Orange/Los Angeles Counties
(760) 943-7552 San Diego/Riverside Counties
HUD/FHA Inspector ID #I078
Originally Posted By: dvalley
. It’s well worth the money. I love it.
The http://www.homeinspectorstore.com/ is under construction, but I can tell you that Inspector Tools has one of the the best deals for this particular meter.
David Valley
MAB Member
http://www.masscertified.com
Originally Posted By: lkage
Yes, an exceptional tool. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Hey thanks guys for the suggestions. I’m a little confused. The text description says nothing about invasive or pin type measuring yet the catalog shows accesories including what looks like meter leads. Are these for penetrating drywall, wood etc?
Originally Posted By: phinsperger
Like Ted and Rick, I prefer the GE SurveyMaster Protimeter. The digital readout is nice as well it has a led indicator.
Quote:
I'm a little confused. The text description says nothing about invasive or pin type measuring yet the catalog shows accesories including what looks like meter leads. Are these for penetrating drywall, wood etc?
If you're referring to the Tramex Moisture Encounter Plus, the pic does display two leads in the rear pocket but (like it states), this is an accessory only. Those leads do not adapt to the Tramex. I believe they are utilizing a mock case that is meant to be used for other meters also. The leads you are seeing are used on other meters, to get into tight areas, but the Tramex (that I own) does not have that option.
There is a much more expensive Tramex ($1100) The Tramex Concrete Moisture Meter and Relative Humidity Meter Datalogger Item #: M405-3982 that utilizes the Humidity/Temperature probes, but that tool is not worth the investment for a typical HI.
David Valley
MAB Member
yeah that is way out of my price range. Thanks for the info.
