any of you guys ever see a ...
These message board pages are now for archival purposes only.  Please visit https://www.nachi.org/forum/ for our most recent forum discussions.
AuthorMessage
five.five
NACHI Member: No
(as of 3/25/07)
Inactive Poster
Posted: Dec 3, 2005 7:46 PM       Post Subject:
Please Note: This user is a non-member guest and is in no way affiliated with NACHI.
any of you guys ever see a fireplace like this?
What are the termination restrictions or rules.
The front of this thing had a screen, similar to solar screen window screening in front of it, leaving me pawing at it, and scratching my head.
gas only, gas logs installed, no access?
[ Image: https://www.nachi.org/bbsystem/usrimages/f/fireplacevent.jpg ]
[ Image: https://www.nachi.org/bbsystem/usrimages/f/fireboxscreen.jpg ]
Back to Top
Michael Boyett
Capital City Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: mboyett
Posted: Dec 3, 2005 7:52 PM       Post Subject:
Yes, I had one similar in my home in Portland. It had an electrically controlled valve and a pilot light. Just flipped the switch on the wall and Presto! ...instant fire. Worked very well except when strong gusty winds created a back-flow from the exhaust. It would sometimes extinguish the fire and the pilot.
Back to Top
Paul Hinsperger
Hinsperger Inspection Services Ltd
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: phinsperger
Posted: Dec 3, 2005 7:57 PM       Post Subject:
Appears to be a direct-vent gas insert.
Back to Top
Larry Kage
Welcome Home Inspection Services, LLC
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: lkage
Posted: Dec 3, 2005 8:38 PM       Post Subject:
Yes it does. I've seen several up here with thermostat control and hand held remote with variable flame and fan control. Dual pipe, combustion air enters through one pipe and exhausts exit through the other pipe...no room air loss. They actually put out quite a bit of heat...about 80% efficient I think. I've seen 20,000 to 38,000 btu units.
One had a round mechanical Honeywell thermostat on the wall across the living room that I mistook for the boiler thermostat...kept waiting for the boiler to ignite until I felt heat on my back and realized what I was doing. icon_redface.gif ...down the hall was the stat I wanted.
Back to Top
Paul Hinsperger
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: phinsperger
Posted: Dec 3, 2005 8:55 PM       Post Subject:
Back to Top
Richard Washington
RW Home Inspections-----rwhomeinspections.com
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: rwashington
Posted: Dec 4, 2005 1:17 AM       Post Subject:
I see alot of these going in around here with the direct vent. Wish I had a picture but is there a clearance requrement since they are no more than 4 or 5 feet off the ground. A home in my neighborhood being built has the direct vent on the porch. I am just thinking of the children (and not so young children) running by and accidentally touching that thing and torching themselves.
Back to Top
Larry Kage
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: lkage
Posted: Dec 4, 2005 8:39 AM       Post Subject:
rwashington wrote:
I see alot of these going in around here with the direct vent. ...but is there a clearance requrement since they are no more than 4 or 5 feet off the ground.
Each fireplace has tested clearances to combustible specification by the manufacturer.
Here's one example (about 3/4 of the way down the page):
http://www.warmingtrendsstoves.com/cambridgedvf_gi.html
Some require no hearth extensions. Combustible material on the floor may be installed up to the insert.
Unless I have the manufacturer's installation specifications there I defer the installation recommending that they verify clearances with the installation instructions through the owner .
Back to Top
five.five
NACHI Member: No
(as of 3/25/07)
Inactive Poster
Posted: Dec 4, 2005 5:18 PM       Post Subject:
a lot of good info there, thanks all.
Darren.
Back to Top
Joseph Hugenroth
Inspect-It 1st
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: jhugenroth
Posted: Dec 21, 2005 2:49 AM       Post Subject:
I agree. This is always a write up for me. I have seen some with hardware cloth around them to help keep fingers off the vent.
Back to Top
