storing combustable gas sensor in cold
Originally Posted By: gmartin2
Is it harmful to store a combustable gas sensor in cold temps?
Geo
ps (above freezing but not by much)
Originally Posted By: rcooke
Geo
Good question .
How about Computers and other electronic equipment .
Does below freezing hurt them ?
Roy sr
Originally Posted By: phinsperger
Most electronic circuits like the cold.
Sensors - I don't know.
Ink cartridges - No
LCD screens (like on laptops & PDA) - No
Hard drives - don't really care as long as the temp is fairly constant.
Years ago you had to wait for your hard drive to warm up before writing or read to it. Otherwise the head would not quite be the same place due to thermal expansion of the parts in the drive. Todays drives are much better but I still wouldn't go from writing at -30oC to reading at +22oC and expect it to work.
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: kwilliams
This time of year ( northeast ) if I don’t
park inside I allways bring my tool bags inside
same with cell phones
if it has a liquid display it might freeze
Originally Posted By: aleleika
I do know that when I leave my palm pilot in the car on extreme cold or extreme heat it acts up and takes fore ever to get back to normal operation.
A. Dan Leleika
www.a-teamhomeinspections.com
Originally Posted By: escanlan
The biggest problems you will have are:
1. Taking the equipment in from cold to warm will cause condensation internally leading to additional issues.
2. No doubt the sensor has a plastic housing as well as other plastic parts. The cold can make them more brittle and prone to cracking and breaking much easier.
Also make sure you read your manual and that there are no adverse affects or innacuracies caused by extended exposure of the sensor to cold temps.
