Your home is free of carbon monoxide.
These message board pages are now for archival purposes only. Please visit https://www.nachi.org/forum/ for our most recent forum discussions.
AuthorMessage
George Martin
Martin Home Inspection LLC
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: gmartin2
Posted: Dec 21, 2005 12:01 PM       Post Subject:
Can this be checked durning the course of a home inspection by using a plug-in detector? Or should you perform tests at the vents of any CO producing devices?
Geo
Back to Top
Gerry Beaumont
Gerry Beaumont Consulting
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: gbeaumont
Posted: Dec 21, 2005 12:07 PM       Post Subject:
Hi to all,
George it can be checked, but I would not go with a plug in tester, if you are going to be relying on or reporting the CO levels then at the very least you should use a properly calibrated CO meter, I use a Kane May.
Regards
Gerry
Back to Top
George Martin
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: gmartin2
Posted: Dec 21, 2005 3:00 PM       Post Subject:
thanks gerry
I, ve got an extech hand held that I use. What brought it up was that an inspector told an acquaintance of mine that his home was 'free of CO' & that got me thinking about using a plug-intype.
Geo
Back to Top
Caoimh?n P. Connell
NACHI Member: No
(as of 3/25/07)
Inactive Poster
Posted: Dec 22, 2005 1:38 AM       Post Subject:
Please Note: This user is a non-member guest and is in no way affiliated with NACHI.
Hello Mr. Martin:
I would like to chime in with Mr. Beaumont. Most ?plug-in? style CO monitors don?t actually measure CO per se, but rather are meant to mimic our blood?s longer term response to CO.
For screening purposes, I agree that it is more appropriate to use a direct reading instrument that can be calibrated in the field.
Caoimh?n P. Connell
Forensic Industrial Hygienist
www.forensic-applications.com
(The opinions expressed here are exclusively my personal opinions and do not necessarily reflect my professional opinion, opinion of my employer, agency, peers, or professional affiliates. The above post is for information only and does not reflect professional advice and is not intended to supercede the professional advice of others.)
AMDG
Back to Top
David Valley
Certified Massachusetts Home Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: dvalley
Posted: Dec 24, 2005 7:39 AM       Post Subject:
I agree...plug-ins are crap.
I carry a low level (battery operated) Co detector in my tool bag that stays on continuously 24 hours a day. I?ve had this alarm activate several times (in the past) during a home inspection. When I do get an audible alarm from this specific detector, I pull out my UEI CO Detector to confirm Co levels within the home. Sure enough?high levels.
Co levels are checked in every home I inspect.
David Valley
MAB Member
http://www.masscertified.com
Back to Top
