Chimney / furnace flue
These message board pages are now for archival purposes only.  Please visit https://www.nachi.org/forum/ for our most recent forum discussions.
AuthorMessage
David Mack
Keystone Home Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: dmack
Posted: Dec 22, 2005 9:57 PM       Post Subject:
Some infromation on the distance of a furnace flue to the chimney flue would be appreciated. Question is I remember reading that a chimney flue should be 5' above the furnace flue, in a different BB, is this true? Additionally, Will the cap also increase the chance that furnace exhaust may be sucked douwn the chimney flue? Sorry abut the pictures. The first picture shows both flues (very poorly) Flue on left is chimney, flue to right is furnace. The second picture shows the clearance from furnce flue to the cap.
[ Image: https://www.nachi.org/bbsystem/usrimages/1/11-01-05_004.jpg ]
[ Image: https://www.nachi.org/bbsystem/usrimages/1/11-01-05_0071.jpg ]
Back to Top
John Rupert
Solitaire Heating & Cooling HVAC Mechanical Inspection Service
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: jrupert
Posted: Dec 27, 2005 5:15 PM       Post Subject:
The lateral run from the furnace to the chimney is based the BTUH of the furnace, the distance to the chimney, the furnace type or efficiency, the venting material type (single wall or double wall) is the furnace the only appliance venting to the same location, how many elbows in the flue run etc?all plugged in to the AGA/GAMA venting tables, etc? What I trying to say this is not a simple calculation and no rule of thumbs should be applied.
Depending on how old the furnace the venting may not meet the new GAMA table but this does not necessarily mean that it?s wrong, it may have complied with the manufactures guidelines at the time of installation
Generally 60% efficient furnaces with a venting over 10ft lateral with more then 2 elbows may be an issue, newer 80% efficient furnaces should be under 10ft
The vent connector from the furnace to the chimney should slope a minimum of ? inch per lineal foot towards the furnace
With the proper flue cap, the furnace flue particulates should not back draft down the chimney providing the house is not under a negative pressure
John Rupert
Accurate Property Inspections
CSG Training (HVAC Training & Consulting)
Back to Top
Marcel Cyr
Cyr Home Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: mcyr
Posted: Dec 27, 2005 7:07 PM       Post Subject:
I will agree with John on this one, because I have no idea what he is talking about.
I did notice that the chimney mason that constructed this chimney and the roofer that installed the flashing need more educated experience in the installation.
I am not a strong advocate of silicone caulking for sealing exterior counter flashing. JMO.
Marcel
P.S. No, there is not enough space from the top of the flue and the rain sheild cap.
Back to Top
