Water Treatment for heating ( boiler) anyone??
These message board pages are now for archival purposes only.  Please visit https://www.nachi.org/forum/ for our most recent forum discussions.
AuthorMessage
Patrick Bolliger
Home Site Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: pbolliger
Posted: Dec 23, 2005 12:27 PM       Post Subject:
Anyone know of the best way to add water treatment to a boiler (heating) single pipe hydronic system? I believe Kek is the name of the treatment.
My buddy has a system that was treated with Kek many years ago when the system was installed and he wants to add some since it is probably all gone by now. No easy way to do with the current pipe system. He has a drain and a TPR but where do you add the Kek??? Anyone..
Back to Top
Roy Cooke
Roys Home Inspection
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: rcooke
Posted: Dec 23, 2005 2:00 PM       Post Subject:
Single pipe WOW ! very uncommon . I think I would have the water tested before you add more chemical. Any small Motor home 12 volt pump would do it well . I use one to runn Winshiel anti freeze through my under ground watering system to my lawn.
Yes I have self drains but they do not always work . Fixed two breaks and then got smart.
Roy sr A happy NACHI member
Back to Top
Jay Moge
NACHI Member: No
(as of 3/25/07)
Very Active Poster
Posted: Dec 23, 2005 4:00 PM       Post Subject:
Please Note: This user is a non-member guest and is in no way affiliated with NACHI.
typicly a boiler tech would drop the altitude of the system, use the drain as an access valve and as Roy said, use a small pump to add to remaining water in system. close system and run/test. it's pretty tricky if you've never done it before so i'd call for help. icon_cool.gif icon_wink.gif
Back to Top
