QOD for 05/05/04 (structural)
These message board pages are now for archival purposes only. Please visit https://www.nachi.org/forum/ for our most recent forum discussions.
How should you report the conditions as seen in the photograph ?
Acceptable for an older brick foundation0%0
In need of some repair and maintenance0%0
Needs evaluation buy a Structural or Professional engineer100%53
Total voters: 53. This poll is closed.
AuthorMessage
Gerry Beaumont
Gerry Beaumont Consulting
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: gbeaumont
Posted: May 5, 2004 11:21 AM       Post Subject:
hi to all,
another foundation question today.
regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Back to Top
Jeffrey Pope
JPI Home Inspection Service
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: jpope
Posted: May 5, 2004 11:25 AM       Post Subject:
Jeff Pope
(661) 212-0738
Back to Top
Kevin McMahon
ABC Home Inspection, LLC
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: kmcmahon
Posted: May 5, 2004 11:40 AM       Post Subject:
Back to Top
Timothy Gardner
Inspecx, LLC.
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: tgardner
Posted: May 5, 2004 5:33 PM       Post Subject:
I particularly like the "buy a structural engineer" pun. - tg
Back to Top
Lew Lewis
NACHI Member: No
(as of 3/25/07)
Inactive Poster
Posted: May 5, 2004 8:18 PM       Post Subject:
Please Note: This user is a non-member guest and is in no way affiliated with NACHI.
Gerry,
Is the brick section actually supporting the framing or was the brick added at a later time?. It looks like there may be piers as the original support. Correct me if I'm wrong.
Do you really need a P.E.?. Just tell them to remove and replace the entire brick wall; it's obviously failed.
Neal
Back to Top
Ryan Jackson
NACHI Member: No
(as of 3/25/07)
Active Poster
Posted: May 5, 2004 11:16 PM       Post Subject:
Are you going to design it, Lew?
Ryan Jackson, Salt Lake City
Back to Top
Robert OConnor
Eagle Engineering & Inspections
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: roconnor
Posted: May 5, 2004 11:27 PM       Post Subject:
Be very careful there Lew ... not only should an HI not get into specific repair methods, but if that really is a bearing wall or masonry infill intended to shore up an undersized/deteriorated perimeter beam, the whole house may come down ... icon_eek.gif
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
Back to Top
Lew Lewis
NACHI Member: No
(as of 3/25/07)
Inactive Poster
Posted: May 6, 2004 8:33 PM       Post Subject:
[Are you going to design it, Lew?[
No, I am not going to design it; that's not my job, Ryan.
Robert, if a contractor with half a brain does the repair, it won't fall down.
I guess my point is that this "get a P.E" gets carried too far, IMO. I see H.I. reports that comment on one cracked floor joist in a basement that recommend an engineer.
Neal
Back to Top
Jeffrey Pope
NACHI Member: Yes
(as of 3/25/07)
NACHI Member
User: jpope
Posted: May 6, 2004 9:16 PM       Post Subject:
Neal,
As I see it, it is our duty as HI's to (I'll say it again) "recommend or defer to the highest authority." In this case that would certainly be a PE.
Any contractor that would take on this project would undoubtedly be required to have plans that are approved by a PE before they could even start the work or get permits.
Our recommendation for the "higher authority" of a PE is prudent as we would expect that appropriate permits be obtained prior to the commencement of any work.
If our recommendation was simply for a contractor that subsequently failed to obtain plans and permits, we could find ourselves partially liable (IMHO).
Jeff Pope
(661) 212-0738
Back to Top
Ryan Jackson
NACHI Member: No
(as of 3/25/07)
Active Poster
Lew: If you say "have a contractor with half a brain re-build your wall", you may as well have designed it. If you say "have engineer address wall failure", you have transferred the liability off of your shoulders.
Back to Top
