Old 7/11/18, 10:31 PM
Joshua LeBeau's Avatar
Joshua LeBeau Joshua LeBeau is offline
Default Basement Air Intake
Four inch PVC pipe coming into the basement of the house attached to a fan.
Fan is drawing in air from the outside only when the oil fired hot water baseboard system is run.
The vertical insulated portion stops about 18" from the floor and it is anchored to the floor.
Has anyone seen this before and the purpose of it.
Why on a freezing cold day would you run the boiler and draw cold air into the basement?
Thanks in advance!
Basement Air Intake-2018-6-11-53-jpg
Joshua & Michelle LeBeau
www.HomeInspectionsbyJML.com
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/11/18, 11:14 PM
Roy D. Cooke, Sr's Avatar
Default Re: Basement Air Intake
I do not like vented Crawl spaces ..
http://www.advancedenergy.org/portal...ble%20Duty.pdf
https://info.ornl.gov/sites/publicat...s/Pub33059.pdf
Old 7/12/18, 12:23 AM
That is a lot of information Roy, thanks, but does that apply to a full size basement as well?
Old 7/12/18, 7:38 AM
Joshua L. Frederick Joshua L. Frederick is online now
Thanks in advance!
Combustion air for boiler.
http://northwestohiohomeinspector.com
Defiance home inspector
Northwest Ohio home inspector
Old 7/12/18, 7:41 AM
Originally Posted by rcooke View Post
Roy, the info you provided has absolutely nothing to do with his post??
Old 7/12/18, 7:53 AM
Yes full basement should not be open to the outside .
Old 7/12/18, 8:21 AM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
That could be a louvered control exterior combustion air intake fan.
Power Vent Openings & Louvers for Combustion Air
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Old 7/12/18, 9:02 AM
Thanks good information Marcel
Old 7/12/18, 9:20 AM
John Olson John Olson is online now
Thanks Marcel, I will see these with manual dampers, which makes no sense at all.
Old 8/10/18, 10:16 AM
Jon Walter Jon Walter is offline
Community Guest
Please Note: jwalter5 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I noticed today that there is a massive air return in my unfinished basement. The opening is about 2 meters from the blower, and as large in diameter as the return duct coming from the upstairs
Will capping off this return or limiting the basement's supply vent cause any problems for the equipment, or lower efficiency?
