Old 6/11/18, 12:45 AM
Yu Zhang Yu Zhang is offline
Real Estate Agent
Please Note: yzhang2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Is this downspout? If so not fully enclosed?
Saw the downspout in the picture at a 10 years old townhouse in Colorado. The front left open. Is this downspout? If it is, what one side is left open?
Thanks
Is this downspout? If so not fully enclosed?-20180610_100429-jpg
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/11/18, 1:05 AM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Default Re: Is this downspout? If so not fully enclosed?
Where did the other end lead to?
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 6/11/18, 8:28 AM
Real Estate Agent
It leads to a black pipe opening on the ground. Not far away is the concrete walkways and then street. I believe the water drains from there to the street in the pipe under the concrete.
Old 6/11/18, 9:31 AM
Jeffrey R. Jonas's Avatar
For those of us in the frigid North... it is a Commercial grade downspout. The open side faces outwards away from the wall. The purpose is to allow water to drain WHEN the water in the pipe begins to freeze, preventing blockage from ice buildup, a very common problem during early Winter and freeze/thaw cycles.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 6/11/18, 11:06 PM
Real Estate Agent
Thanks for the info. Start making sense now.
But why residential properties don't need it as they can freeze too? Secondly this four story building is high. When there is a lot of water coming down, water can go out the open face and get onto the ground instead of being fully drained into the pipe ?A valid concern?
Bill
Old 6/12/18, 7:45 PM
Chuck Evans's Avatar
Well, whad'ya know? Don't see many o them around here.
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
Awards Committee Member
Old 6/12/18, 8:26 PM
Imagine a commercial roof (flat) when the scuppers and downspouts freeze up! I'm sure you've seen scuppers clogged with leaves and debris causing water to pool on the roof. Same thing only much worse.
(Keep in mind Yu's photo is 90 degrees out of rotation).
Jeffrey R. Jonas
Owatonna, Minnesota
Old 6/12/18, 8:35 PM
I got that. it's the concept of freezing that is foreign.
Houston, TX
