Old 1/25/13, 10:00 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Default Heat Source in Every Room?
A local AHJ said that One supply duct opening at living room, (opposite wall from gas furnace) is adequate at supplying sufficient heat to All habitable rooms, including three bedrooms; Even with doors closed.
Heat Source in Every Room?-p1010089-jpg   Heat Source in Every Room?-p1010101-jpg
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/25/13, 10:11 PM
Bob Elliott's Avatar
Default Re: Heat Source in Every Room?
Obviously you know more than him.
Thought the door was sinking in the first shot for a second .
Old 1/25/13, 10:18 PM
Originally Posted by belliott View Post
Obviously you know more than him. I try.
Also no thermostat, The knob at bottom right controls the heat.
I turned it up a little and within a few minutes 3 smoke alarms went off.
Old 1/25/13, 10:21 PM
Yikes...how old is that thing?
Time to update.
Old 1/25/13, 10:30 PM
Time to update.
Old, probably original, house built in the mid-40's. Manufacturer is "Winkler", Lebanon Indiana, serial # 2239.
Old 1/26/13, 12:28 AM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
When did he say it, 1940?
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.homeinspectionpeoria.com
Old 1/26/13, 12:47 AM
Juan C. Jimenez Juan C. Jimenez is offline
Were you writing up lack of heat sources in the rooms?
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Richmond Chimney Sweep
Richmond Radon Testing
Old 1/26/13, 1:19 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
The AHJ is correct. The requirement for heat does not say that it has be be distributed via duct to each room. The heater has to be capable of heating every room to a minimum of 70 degrees, measured 36" above the base board. Simple as that.
Even if it's 90 degrees in the room where the heater is located, if the habitable spaces reach 70 degrees, it's compliant.
Smoke detectors will often sound when a unit is fired-up for the first time of the season. The dust that has accumulated on the burner chambers will smoke.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/26/13, 1:30 AM
if the habitable spaces reach 70 degrees, that's the if; when doors are closed preventing heat to enter. The furnace has been running all winter. It wasn't fired-up today.
Old 1/26/13, 1:36 AM
A bedroom is no longer a bedroom if the door must stay open.
You crazy cal guys do not need heat and in some cases no need for privacy. Lol
Old 1/26/13, 1:46 AM
Paul Pendley Paul Pendley is offline
You are right but wait til the appraiser comes around!!! Funny how they are now calling out things out now!!!
Premier Property Inspections
916-361-1021
Old 1/26/13, 2:49 AM
Hi Paul
Please explain why you agree with Jeff besides you both being in a warm weather state.
Chris and I live in Illinois so do you think you can please explain for all of us the exact amount of air space required under a closed door for that 1940 furnace to push heated air into into a closed bedroom space and heat it to a required 70 degree temperature.
First explain how return vents work and why they are used then tell us if it is OK to open a window in in -50 degree weather as we sometimes get that in Illinois ,how about you ?
Back to subject bedrooms are required to have privacy so if the door must be open to heat the room is that OK ?
Thanks and glad you see it my way now .
P.S we do not surf here either .LOL
Old 1/26/13, 6:51 AM
Bob's exaggerating, but only a little. The coldest day ever recorded in Illinois was -38░F and it happened in 2009. So much for global warming in that location.
I really don't care what the construction standards might say, if a decent sized room(especially a bedroom) has no heat source, I call it out as a defect. It's too cold in this state to report it otherwise.
Cameron Anderson
Since 2004
Old 1/26/13, 7:15 AM
Joshua L. Frederick Joshua L. Frederick is online now
Who cares about any requirements, codes, or whatever? Common sense to me and that's how I'd inform my clients. Like Cameron stated, that's how I'd report it - No/minminal heat at such and such areas - improve/correct as needed. If they are good with it (living with a central furnace), then so be it. I won't be living there and don't care. Maybe they'll leave the doors open at night so they can hear each other saying, "Goodnight, John Boy, Goodnight Mary Ellen"......
Old 1/26/13, 10:39 AM
Well, since the OP was inferring that the AHJ was "wrong" by stating that this is a compliant heat source, the thread was not about a "common sense" issue. The AHJ is correct according to construction standards and model codes.
According to building standards, yes it is.
That certainly doesn't stop us from making recommendations for "upgrades," but to call this a defect is wrong.
Having the ability to heat a residence is a life/safety concern. Privacy is not.
Jeff Pope
Santa Clarita CA
(661) 212-0738
No heat source ragaian Miscellaneous Discussion for Inspectors 3 8/10/11 11:53 PM
Radiant heating in ceilings bleibgott Ancillary Inspection Services 13 4/26/10 10:27 PM
More Moisture Discoveries jpope Interior Inspections 30 8/16/07 2:54 AM
Heat source required in bathrooms menser Inspecting HVAC Systems 7 7/13/06 1:57 PM
